Arduino snmp protocol
Hi, I'm want to build an Agent device that sends Temp to the MIB with snmp protocol via Ethernet.
and this device should be able to change IP address from web server...
I have build web server to changing IP address and gateway and IT WORKS.
for changing mode between SETUP and Agent I have used switch case and a push button.
but arduino doesn't send data to MIB...
when I put snmp code at first case it works(webserver doesn't work)
please help me, this is my code:
    val = digitalRead(inPin);
switch(val) {
case LOW:
          EthernetServer server(80);
          server.begin(); //starting the server
  if (client) {
    TextFinder  finder(client );
    while (client.connected()) {
      if (client.available()) {
        if( finder.find("GET /") ) {
          if (finder.findUntil("setup", "\n\r")){
          if (finder.findUntil("SBM", "\n\r")){
            byte SET = finder.getValue();
              while(finder.findUntil("DT", "\n\r")){
                int val = finder.getValue();
                // if val from "DT" is between 1 and 6 the according value must be a MAC value.
                if(val >= 1 && val <= 6) {
                  mac[val - 1] = finder.getValue();
                // if val from "DT" is between 7 and 10 the according value must be a IP value.
                if(val >= 7 && val <= 10) {
                  ip[val - 7] = finder.getValue();
                // if val from "DT" is between 11 and 14 the according value must be a MASK value.
                if(val >= 11 && val <= 14) {
                  subnet[val - 11] = finder.getValue();
                // if val from "DT" is between 15 and 18 the according value must be a GW value.
                if(val >= 15 && val <= 18) {
                  gateway[val - 15] = finder.getValue();
            // Now that we got all the data, we can save it to EEPROM
            //for (int i = 0 ; i < 6; i++){
              //EEPROM.write(i + 1,mac[i]);
            for (int i = 0 ; i < 4; i++){
              EEPROM.write(i + 7, ip[i]);
              EEPROM.write(i + 11, subnet[i]);
              EEPROM.write(i + 15, gateway[i]);
            // set ID to the known bit, so when you reset the Arduino is will use the EEPROM values
            EEPROM.write(0, 0x92);
            // if al the data has been written to EEPROM we should reset the arduino
            // for now you'll have to use the hardware reset button
          // and from this point on, we can start building our setup page
          // and show it in the client's browser.
          client.println("Content-Type: text/html");
          client.println();
          for (int i = 0; i < 4; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table0[i])));
            client.print( buffer );
          for (int i = 0; i < 3; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[i])));
          client.print(mac[0],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[3])));
          client.print(mac[1],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[4])));
          client.print(mac[2],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[5])));
          client.print(mac[3],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[6])));
          client.print(mac[4],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[7])));
          client.print(mac[5],HEX);
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[i])));
          client.print(ip[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[4])));
          client.print(ip[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[5])));
          client.print(ip[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[6])));
          client.print(ip[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[0])));
          client.print(subnet[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[1])));
          client.print(subnet[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[2])));
          client.print(subnet[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[3])));
          client.print(subnet[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[0])));
          client.print(gateway[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[1])));
          client.print(gateway[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[2])));
          client.print(gateway[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[3])));
          client.print(gateway[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[4])));
          for (int i = 0; i < 7; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table5[i])));
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[5])));
          client.println();
          client.println();
          client.println("<tr><td><font color=\"red\" size=\"2\" face=\"Verdana\">&nbspYou can not change the MAC address</font></td></tr></table>
    delay(1);
    client.stop();
  } break;
case HIGH:
    SnmpAgent.begin();
    SnmpAgent.listen();
  if (millis() - lastMillis > 10000) {
    Sensors.requestTemperatures(); // Send the command to get temperatures
    dtostrf(Sensors.getTempCByIndex(0), 1, 1, temperature);
    lastMillis = millis();
} delay(1);
