Arduino software problem
Hello,
I've build a security system but i have a problem, when the system is triggered i can't turn it off and when i activate the system immediately sees the pir sensor movement. This is the code i used:
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#include <LiquidCrystal_SR.h>
#include <LiquidCrystal_SR2W.h>
#include <LiquidCrystal_SR3W.h>
#include <RTClib.h>
#include <Servo.h>
#include <Keypad.h>
#include <Password.h>
#include <Wire.h>
//Servo
Servo myservo;
int pos = 90; // variable to store the servo position
int passwd_pos = 15; // the postition of the password input
//Password
Password password = Password( "7196" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
char keys[ROWS][COLS] = { // Define the Keymap
'1','2','3','A' }
'4','5','6','B' }
'7','8','9','C' }
'*','0','#','D' }
byte rowPins[ROWS] = {
8, 7, 6, 9 }; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
5, 4, 3, 2}; //connect to the column pinouts of the keypad
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Assignign arduino pins to LCD display module
int greenLED = 12;
int redLED = 11;
int pirPin1 = 10;
int pirPin2 = 10;
int alarmled = 13;
int alarmStatus = 0;
int zone = 0;
int alarmActive = 0;
void setup(){
lcd.begin(16, 2);
//Adding time
Wire.begin();
myservo.attach(2); // attaches the servo on pin 2 to the servo object
displayCodeEntryScreen();
pinMode(redLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(pirPin1, INPUT);
pinMode(pirPin2, INPUT);
digitalWrite(redLED, LOW);
digitalWrite(greenLED, HIGH);
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
myservo.write(pos);
void loop(){
keypad.getKey();
if (alarmActive == 1){
if (digitalRead (pirPin1) == HIGH)
zone = 0;
alarmTriggered();
if (digitalRead(pirPin2) == HIGH)
zone = 3;
alarmTriggered();
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
if (passwd_pos - 15 >= 5) {
return ;
lcd.setCursor((passwd_pos++),0);
switch (eKey){
case '#':
passwd_pos = 15;
checkPassword();
case '*':
password.reset();
passwd_pos = 15;
default:
password.append(eKey);
lcd.print("*");
void alarmTriggered(){
int expected_pos;
int incr;
digitalWrite(alarmled, HIGH);
password.reset();
alarmStatus = 1;
// alarmActive = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("BEWEGING! PIN:");
checkPassword;
lcd.setCursor(0,1);
if (zone == 3)
lcd.print("SMS VERSTUURD!");
expected_pos = 65;
if(zone == 0){
expected_pos = 65;
lcd.print("SMS VERSTUURD! ");
if (expected_pos > pos) {
incr = 1;
incr = -1;
for (pos = pos; pos != expected_pos; pos += incr) {
myservo.write(pos);
delay(5);
for(pos = 0; pos < angle; pos += 1)
myservo.write(pos);
delay(20);
for(pos = angle; pos>=1; pos-=1)
myservo.write(pos);
delay(20);
void checkPassword(){ // To check if PIN is corrected, if not, retry!
if (password.evaluate())
if(alarmActive == 0 && alarmStatus == 0)
activate();
else if( alarmActive == 1 || alarmStatus == 1) {
deactivate();
else {
invalidCode();
void invalidCode() {
password.reset();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("VERKEERDE CODE!");
lcd.setCursor(0,1);
lcd.print("OPNIEUW!");
digitalWrite(greenLED, LOW);
digitalWrite(redLED, HIGH);
delay(10000);
void activate() {
digitalWrite(2, HIGH);
lcd.setCursor(0,0);
lcd.print("SYSTEEM ACTIEF!");
lcd.setCursor(0,1);
lcd.print("VERLAAT KAMER!");
alarmActive = 1;
password.reset();
delay(22000);
void deactivate()
digitalWrite(alarmled, LOW);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("GEDEACTIVEERD");
alarmActive = 0;
password.reset();
delay(5000);
void displayCodeEntryScreen()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("PINCODE:");
lcd.setCursor(0,1);
lcd.print("BEVEILIGING!");
int pirPin1 = 10;
int pirPin2 = 10;
How is the PIR wired ?
Welcome to the Forum. Please read these two posts:
How to use this forum - please read.
and
Read this before posting a programming question ...
void loop(){
  keypad.getKey();
  1. The ONLY argument for putting the { on the same line as the function/statement is to save real estate. You look really stupid when you follow that with a blank line.
  2. There is NO excuse for jamming the { up against that statement. Usewhitespacetomakethestatementreadable.
  3. There is no point in calling getKey() when you throw the result away.
