Arduino software2.0.0beta.7 in not use LCD libray.
LCD libray not install. and Error - proxyconnect tcp: dial tcp: lookup _: no such host
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Exactly which library are you trying to install and how are you doing it ?
hello sir,
libare nto downloding in 2.0.0beta.9.
Error is <> Downloading bb_spi_lcd@2.0.0
Failed to install library: bb_spi_lcd:2.0.0.
Error: 2 UNKNOWN: downloading library: Get "https://downloads.arduino.cc/libraries/github.com/bitbank2/bb_spi_lcd-2.0.0.zip": proxyconnect tcp: dial tcp: lookup _: no such host
Hi @skyyyyy
Are you connecting to the Internet through a network proxy?
Hi
Yes my mac is connected to internet.
OK, but is it using a proxy? If so, you will need to configure the IDE for it:
- Select File > Preferences from the Arduino IDE's menus.
- Click the "Network" tab.
- Select the radio button next to "Manual proxy configuration".
- Set the options for your proxy configuration.
Alternatively, you may prefer to use the classic Arduino IDE, which has an automatic proxy configuration capability. That capability has not yet been added to the beta phase Arduino IDE 2.x you are using, which is primarily only intended to be used by advanced users for beta testing and is not yet appropriate for use by beginners.
Hi
yes i am doing this but this problem not solve.and Arduino IDE 2.x not show wedide.
Does it work if you use Arduino IDE 1.8.15?
I'm not familiar with this word "wedide". What does it mean?
