Arduino Sound Sensor
Hello, i build module like this http://tinkerlog.com/2007/10/22/diy-tengu-on-a-breadboard/
I achieve results: clap hands the robot is start to go, when next clap robot is stopping.
That work fine. But i have question how get work douple clap ?
int potPin = 2;    // select the input pin for sound sensor
int ledPin = 13;   // select the pin for the LED
int val = 0;
int amp = 0;
int go = 0;
  pinMode(ledPin, OUTPUT);  // declare the ledPin as an OUTPUT
  val = analogRead(potPin);
  amp = (val >= 512) ? val - 512 : 512 - val;
  if (amp > 100) {
  digitalWrite(ledPin, HIGH);
  delay(20);
  if  (go == 0)
  motor.start
  go = 1;
 motor.stop
  go = 0;
  digitalWrite(ledPin, LOW);
The trick is to remember the timestamp of the last clap, and if the delta is less than some value - e.g. 500 millis() - consider it a double clap.
patched your code a bit to get you started …
int val = 0;
int amp = 0;
int go = 0;
unsigned long lastClap = 0;
unsigned long nowClap = 0;
unsigned int claps = 0;
#define DOUBLECLAPTHRESHOLD 500
  // READ THE SENSOR
  amp = (val >= 512) ? val - 512 : 512 - val;  // amp = abs(val-512);
  // COUNT THE CLAPS
  if (amp > 100) // threshold
    nowClap = millis();
    claps = 1;
    if (nowClap - lastClap < DOUBLECLAPTHRESHOLD) claps = 2;
    lastClap = nowClap;
  Serial.println(claps, DEC);
  // ACT ON THE NR OF CLAPS
  switch(claps)
  case 0:  // DO NOTHING
  case 1: // SINGLECLAP
    // motor.start(); // to be defined
  case 2: // DOUBLECLAP
    // motor.stop();  // to be defined
  default:  // UNDEFINED NR CLAPS
Could you tell me how do i go about making my robot move (dance) to dethmetal using the same sensor? i have a 4wd rover and a mega 2560
i want to make a robot that would go forward on one clap backwards on two left on three and right on four pls advice on the arduino ide code pls help i a a beginner to this and i do not know how to program pls help
If we code it for you yo never will learn, first give it a serious try yourself
If it does not work we can help based upon YOUR code.
