Arduino Spaceship Interface Code
Im on the 2nd project of arduino starter kit and i dont understand whats wrong with my code.
This is my CODE:
int switchState = 0;
pinMode(3 , OUTPUT);
pinMode(4 , OUTPUT);
pinMode(5 , OUTPUT);
pinMode(2 , INPUT);
switchState = digitalRead(2);
if (switchState == LOW){
digitalWrite(3, HIGH);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
else {
digitalWrite(3, LOW);
digitalWrite(5, HIGH);
delay(250);
digitalWrite(4, HIGH);
delay(250);
Thank you for you help and attention
There's a section of the forum dedicated to the Starter Kit:
http://forum.arduino.cc/index.php?board=86.0
Have you looked in there?
Are we supposed to guess? The code does something, assuming it compiles. You need to explain what it actually does. You expect it to do something. You need to explain that.
How IS the switch wired? You do have an external resistor, don't you? If so, why? Using the internal pullup resistor makes it so much easier to wire a switch (one leg to the digital pin and the other to ground).
