Arduino Spaceship Interface Code
Im on the 2nd project of arduino starter kit and i dont understand whats wrong with my code. Everything is done exactly like the book in the circuit This is my CODE:
int switchState = 0;
void setup() { // put your setup code here, to run once: pinMode(3 , OUTPUT); pinMode(4 , OUTPUT); pinMode(5 , OUTPUT); pinMode(2 , INPUT);
void loop() { // put your main code here, to run repeatedly: switchState = digitalRead(2); if (switchState == LOW){
digitalWrite(3, HIGH); digitalWrite(4, LOW); digitalWrite(5, LOW); } else {
digitalWrite(3, LOW); digitalWrite(4, LOW); digitalWrite(5, HIGH);
delay(250); digitalWrite(4, HIGH); digitalWrite(5, LOW); delay(250); } }
Thank you for you help and attention
There doesn't appear to be anything obviously wrong with your code. What makes you think there is?
Try this pinMode(2 , INPUT_PULLUP); // turns on internal pullup resistor.
dannable:
There doesn’t appear to be anything obviously wrong with your code. What makes you think there is?
Because when it gives me an error
CrossRoads: Try this pinMode(2 , INPUT_PULLUP); // turns on internal pullup resistor.
Arduino: 1.6.3 (Windows 7), Placa:"Arduino Uno"
sketch_may06a.cpp.o: In function `loop':
C:\Program Files (x86)\Arduino/sketch_may06a.ino:32: undefined reference to `delay'
C:\Program Files (x86)\Arduino/sketch_may06a.ino:35: undefined reference to `delay'
C:\Users\casa\AppData\Local\Temp\build3596501948761043943.tmp/core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:32: undefined reference to `init'
collect2.exe: error: ld returned 1 exit status
Erro ao compilar.
Erro ao compilar.
Este relatório teria mais informação com "Mostrar output verboso durante a compilação" ativo em Ficheiro > Preferências
That looks like a failed install then.
CrossRoads:
Thank you so much.
I feel so dumb now.
Seriously aprettiated bro. :slight_smile:
wydtron: Arduino: 1.6.3 (Windows 7), Placa:"Arduino Uno"
Erro ao compilar.
Erro ao compilar.
happened to me too, just re-install :)
