I recently purchased a Speedsensor from joy-it Speed sensor | Joy-IT
it came a example code which works fine for me.
But i dosent really understand how the Programm works. I have programmed arduino before but I am still an beginner. Can someone explain to me what it does.
Thanks in advance,
Cori
Here is the code:
MODERATION EDIT- added code tags
// sen-speed Demo
// The code measures the revolutions of the encoder disk over a period of
// time (5 seconds by default), then converts it to revolutions per minute
// and outputs it via the serial interface.
// library import
#include "TimerOne.h"
#define pin 2
// needed variables
int interval, wheel, counter;
unsigned long previousMicros, usInterval, calc;
counter = 0; // setting counter to 0
interval = 5; // 5 second interval
wheel = 20; // number of encoder disc holes
calc = 60 / interval; // calculate interval to one minute
usInterval = interval * 1000000; // convert interval to micro
// seconds
wheel = wheel * 2; // number of encoder disc wholes times 2
pinMode(pin, INPUT); // setting pin 2 as input
Timer1.initialize(usInterval); // initialize timer with interval time
attachInterrupt(digitalPinToInterrupt(pin), count, CHANGE);
// executes count, if the level on pin 2 changes
Timer1.attachInterrupt(output); // executes output after interval time
Serial.begin(9600); // starts serial interface with 9600 Baud
// counts holes on disc (with filter)
void count(){
if (micros() - previousMicros >= 700) {
counter++;
previousMicros = micros();
// output to serial
void output(){
Timer1.detachInterrupt(); // interrupts the timer
Serial.print("Drehzahl pro Minute: ");
int speed = ((counter)*calc) / wheel;
// calculate round per minute
Serial.println(speed);
counter = 0; // resetting the counter
Timer1.attachInterrupt(output); // restarts the timer for output
void loop(){
// no loop needed
