Arduino+SPI+BLUETOOTH
I am trying to transfer data from an SD to my computer via Bluetooth using an Arduino. I found a code that is similar to my project but instead of using a bluetooth shield they try to transfer the JPEG by SPI. I really need help or guidance on what bluetooth I should use and the coding as well
#include <SD.h>
 File photoFile;
 const int buttonPin = 7;
 const int ledPin = 5;
 void setup(){
  pinMode(buttonPin,INPUT);
  pinMode(ledPin,OUTPUT);
  //Serial.println("initializing sd card");
  pinMode(10,OUTPUT);     // CS pin of SD Card Shield
  if (!SD.begin(10)) {
   Serial.print("sd initialzation failed");
   return;
  //Serial.println("sd initialization done");
 void loop(){
  while(1){
   // Serial.println("press the button to send picture");
   Serial.flush();
   while(digitalRead(buttonPin) == LOW);
   if(digitalRead(buttonPin) == HIGH){
    delay(50);
     delay(200);
     File photoFile = SD.open("pic02.jpg");
     if (photoFile) {
      while (photoFile.position() < photoFile.size()) {
       digitalWrite(ledPin,HIGH);
       Serial.write(photoFile.read());
      photoFile.close();
      digitalWrite(ledPin,LOW);
     else {
      Serial.println("error sending photo");
    //Serial.println("photo sent");
For processing
import processing.serial.*;
 Serial myPort;
 OutputStream output;
  size(320, 240);
  //println( Serial.list() );
  myPort = new Serial( this, Serial.list()[0], 115200);
  myPort.clear();
  output = createOutput("pic02.jpg");
 void draw() {
  try {
   while ( myPort.available () > 0 ) {
    output.write(myPort.read());
  catch (IOException e) {
   e.printStackTrace();
 void keyPressed() {
  try {
   output.flush(); // Writes the remaining data to the file
   output.close(); // Finishes the file
Thought the code might be helpful in helping in someone replying to this post
