I'm trying to drive the LTC1664 DAC from an Arduino (Mega 2560). The SPI data and clock coming out of the Arduino is always synched (rise and falls) for all 4 modes when the DAC data sheet indicates phasing
I've tried all modes, the SS line on the chip is being brought low during the writes (as it should) and I've tried different speeds and
** **shiftOut(), setClockDivider(), setDataMode(), beginTransaction()** **
and
** **endTransaction()** **
Is this a bug in Arduino SPI, something specific to the Mega 2560, should I try an Uno or Due? Help please! Code below o-scope traces.
BTW: The 16 bit word I'm trying to transmit is, 0x3600 (o-scope trace truncated).
#include <SPI.h>
void DAC(unsigned short value, unsigned char channel, int SS_Pin, int model);
enum models{LTC1664};
enum models model;
// set pin 10 as the slave select for the digital pot:
const int DAC_SS_Pin = 22;
// set the DAC_SS_Pin as an output:
// initialize SPI:
SPI.begin();
Serial.println("SPI.begin");
SPI.setClockDivider(SPI_CLOCK_DIV16); SPI.setDataMode(SPI_MODE0);
pinMode(DAC_SS_Pin, OUTPUT);
// go through the six channels of the digital pot:
for (int channel = 1; channel < 6; channel++) {
DAC(128*channel, channel, DAC_SS_Pin, LTC1664);
Serial.println("new loop");
DAC Control
This function controls an LTC1664 Micropower Quad 10-Bit DAC.
The LTC1664 is SPI-controlled,and to command it, you send one 16 bit word,
A3 A2 A1 A0 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 X1 X0
| ADDR | INPUT CODE | DON'T CARE
The circuit:
* CS - to digital pin 22 (SS pin)
* SDI - to digital pin 51 (MOSI pin)
* SDO - to digital pin 50 (MISO pin, not used in this function)
* CLK - to digital pin 52 (SCK pin)
created 18 Mar 2020 (Covid-19, oppsies)
by Danny Holstein
void DAC(unsigned short value, unsigned char channel, int SS_Pin, int model) {
// take the SS pin low to select the chip:
digitalWrite(SS_Pin, LOW); delay(100);
unsigned short buf, b16;
unsigned char *c, b; c = (unsigned char *) &buf;
switch (model)
case LTC1664:
if (channel > 4) channel = 0xF;
buf = (channel << 12) | ((value & 0x3FF) << 2);
SPI.beginTransaction(SPISettings(16000000, MSBFIRST, SPI_MODE0));
b16 = SPI.transfer16(buf);
Serial.print("0x" + String(buf, HEX)); Serial.println("\t0x" + String(b16, HEX) + "\t");
SPI.endTransaction();
default:
delay(100);
// take the SS pin high to de-select the chip:
digitalWrite(SS_Pin, HIGH);
// printf("value = 0x%04x", buf);
