Arduino spi not working
hi there. I have a mega168 chip i've bootloaded. works fine, but no spi. Is there a way to enable this? if i pull the chip out of my arduino board and use it in my new circuit everything works fine. For some reason the atmega168 chip i purchased and bootloaded won't do spi. I placed it in my arduino board with same results so it is definitely the chip. Any ideas? (ive tried it with a second purchased chip with same results)
Which board? One generatino of the NG with an LED on pin 13 had a problem; check out this thread.
You can try getting the signals off the ICSP header to see if it helps.
-j
hi thanks for the response. it seems that it's the chip itself. i have 2 of them breadboarded-not using an arduino. both have no spi. the chip that came with my decimillia works though if i pull it out and place it in my breadboarded circuit. weird.
yeah, very weird. Could you have possibly damaged a pin?
Not sure, is there some fuse settings that would cause it to exhibit this behavior?
-j
