Arduino split data into 5 strings
So basically I want to make a void function that splits the parameter value into 5 global variables. So if I put "05:13:2021:11:06", the numbers should be divided and saved separately in global Strings called hour, minute, year, month, and day.
     splitData("05:13:2021:11:06");
     Serial.println(hour + ":" + minute + ", " + year + "/" + month + "/" + day);
void splitData(String string) {
this should print out 05:13, 2021/11/06
can anyone give me some examples?
consider following just posted in another thread
add a parallel array of ints using atoi() of the tokens
char s [80];
#define MaxTok  10
char *toks [MaxTok];
int
tokenize (
    char       *s,
    const char *sep )
    unsigned n;
    toks [0] = strtok (s, sep);
    for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
    return n;
void dispToks (
    char * toks [])
    for (unsigned n = 0; toks [n]; n++)
        Serial.println (toks [n]);
void loop ()
    if (Serial.available ())  {
        int n = Serial. readBytesUntil ('\n', s, sizeof(s));
        s [n] = 0;      // terminate string
        tokenize (s, ",");
        dispToks (toks);
void setup ()
    Serial.begin (9600);
String hour, minute, year, month, day;
  hour = string.substring(0, 2);
  minute = string.substring(3, 5);
  year = string.substring(6, 10);
  month = string.substring(11, 13);
  day = string.substring(14);
  delay(200);
void loop() {}
Simple is the best. Why did I forget about that? That's actually perfect because the length will always stay constant. Thanks
