Arduino splits float numbers into two( 12.67 displays 12.00 and 67.00
What I'm trying to do is just print the entire float number but it keeps spliting. Also any ideas on how to get character by character a float number then concatenate it and display? I 'm still working on this project and so
I may post some more changes later.
float incomingByte = 0.00;
  Serial.begin(9600);//Prepare serial port for use
  Serial.print("Enter floating point between 1000 to -1000:\n");
  //Serial.print(incomingByte);
  if (Serial.available() > 0)
   incomingByte = Serial.parseInt();
   if(incomingByte > 1000 || incomingByte < -1000)
   Serial.print("Sorry this numebre is out of range\n");
   Serial.print("Try again.\n");
   //incomingByte = Serial.parseInt();
   Serial.println(incomingByte); //without this there is no decimal point
  delay(500);//So serial port isn't overwhelmed.
Look at the documentation for Serial.parseInt() : it stops at the first non-digit character. There is also a parseFloat() function that may work for your case.
thank you, and yes I looked and ended up using
Serial.parseFloat()
