Hi everyone!
I'm trying to use an ATmega328 standalone with external 16 MHz crystal, but it doesn't work.
I firstly uploaded my sketch while the microcontroller was plugged to my arduino uno board, then took it out and plugged it to the breadboard. I connected everything using this pin mapping;
"http://arduino.cc/en/Hacking/PinMapping168"
I also have 2 22pF caps to Gnd on the crystal pins, a 10K reset pin pullup resistor. Pretty much this thing is going on;
"http://arduino.cc/en/uploads/Main/arduinobb_09.jpg"
except that I don't use the voltage regulator, but instead I connected the Gnd and 5V from the board to the rails on the breadboard and then powered the board via USB.
Nothing happens. What am I doing wrong? I also tried to do it without the AREF wire going to the 5V as some tutorials suggest but still nothing happens.
Thanks in advance.
