This is my code.
Sorry for the strange names, the names are from Dutch.
#include "LedControl.h"
LedControl lc = LedControl(7, 5, 6, 2);
int VRx = A0;
int VRy = A1;
int SW = 2;
int xPosition = 0;
int yPosition = 0;
int SW_state = 0;
int mapX = 0;
int mapY = 0;
char richting = 0;//direction
int volgendBlok = 0;//next block
boolean isBlok = false;// see if there is already a falling block
boolean controleGrond = false; //to see if the block is above the ground
int bHuidigX[] = {0, 0, 0, 0 }; //Array that keeps track of the x coordinates of the blocks that fall
int bHuidigY[] = {0, 0, 0, 0 }; //Array that keeps track of the y coordinates of the blocks that fall
int bewegingsnelheid = 0;//movement speed (moving left and right)
int snelheid = 0;//fall speed
int draai = 0;//rotational speed
boolean oBloks[8][16] = {{false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false},
};// Array that stores the dropped blocks
boolean checkEind = false;//to detect if the game ends
bool lijndetected = false;//detect a full line
int volleLijnNummer = -1; // the line that is full
randomSeed(analogRead(A5));
lc.shutdown(0, false);
lc.shutdown(1, false);
lc.setIntensity(0, 8);
lc.setIntensity(1, 8);
lc.clearDisplay(0);
lc.clearDisplay(1);
pinMode(VRx, INPUT);
pinMode(VRy, INPUT);
pinMode(SW, INPUT_PULLUP);
checkEinde();//looks if the game ends
if (checkEind == false)
checkVolleRij();//checks for full rows
verwijderBlok();// refreshes the screen (only the blocks that are falling)
snelheid++;//adds speed (for delay)
bewegingsnelheid++;//adds move speed (for delay)
if (snelheid >= 10) // checks if delay is 10*10 = 100
if (isBlok == false)
isBlok = true;
randomBlok(); //spawns new block
zakBlok();// let the block drop one by one
snelheid = 0;// delay resets
if (bewegingsnelheid >= 9 && controleGrond == false)
besturen();//movement of the block
toonBlok();//shows the falling block
toonoBlok();//shows the blocks that are saved
else if (checkEind == true)
delay(10);
void checkVolleRij()//checks for full rows
for (int i = 0; i < 16; i++)
if (oBloks[0][i] == 1 && oBloks[1][i] == 1 && oBloks[2][i] == 1 && oBloks[3][i] == 1 && oBloks[4][i] == 1 && oBloks[5][i] == 1 && oBloks[6][i] == 1 && oBloks[7][i] == 1)
volleLijnNummer = i;
if (volleLijnNummer > -1)
lijndetected = true;
if (lijndetected == true)
for (int i = 0; i < 8; i++)
oBloks[i][volleLijnNummer] = 0;
for (int j = 0; j < 8; j++)
if (i > volleLijnNummer)
if (oBloks[j][i] == true)
oBloks[j][i] = false;
oBloks[j][i - 1] = true;
lc.clearDisplay(0);
lc.clearDisplay(1);
void checkEinde()//checks for end
if (oBloks[i][15] == true)
checkEind = true;
//methode
void toonoBlok()// turns on the blocks that are saved
for (int y = 0 ; y < 16; y++)
if (oBloks[i][y] == 1)
ledje(i, y, true);
void oBlok()//saves the fallen blocks
for (int i = 0; i < 4; i++)
oBloks[bHuidigX[i]][bHuidigY[i]] = 1;
boolean checkOnder()//checks if the block still can go down
int checkX = bHuidigX[i];
int checkY = bHuidigY[i] - 1;
if (oBloks[checkX][checkY] == 1 || bHuidigY[i] <= 0)
return true;
return false;
void zakBlok()//lower the block
if (checkOnder() == true)
oBlok();
isBlok = false;
draai = 0;
bHuidigY[i]-- ;
char positie()//position of the joystick
if ( mapX > -100 && mapX < 100 && mapY > -100 && mapY < 100)
richting = 0;//deadzone
return richting;
else if (mapX > 0 && mapY > 0)
//Serial.println("Kwadrant 1");
if (abs(mapY) < abs(mapX))
richting = 1;//up
return richting;
else if ( abs(mapY) > abs(mapX))
richting = 3;//right
return richting;
else if (mapX < 0 && mapY > 0)
if (mapY >= mapX)
richting = 2;//down
return richting;
else if (mapY < mapX)
richting = 4;//left
return richting;
else if (mapX < 0 && mapY < 0)
if (mapY >= mapX)
richting = 2;
return richting;
else if (mapX > 0 && mapY < 0)
//Serial.println("Kwadrant 4");
richting = 1;
return richting;
richting = 4;
return richting;
void besturen()//to move the blocks left and right + rotate the block
boolean zijkantL = false;
boolean zijkantR = false;
xPosition = analogRead(VRx);
yPosition = analogRead(VRy);
SW_state = digitalRead(SW);
mapX = map(xPosition, 0, 1023, -512, 512);
mapY = map(yPosition, 0, 1023, -512, 512);
if (zijkantR == false || zijkantL == false)
if (bHuidigX[i] < 1)
zijkantR = true;
if (bHuidigX[i] > 6)
zijkantL = true;
if (positie() == 3)
if (zijkantR == false)
bHuidigX[i]-- ;
if (positie() == 4)
if (zijkantL == false)
//Serial.println(bHuidigX[i]);
bHuidigX[i]++ ;
if (positie() == 1) //draaien
if (volgendBlok != 0)
if (volgendBlok == 1) //I
if (draai == 0)
draai = 1;
bHuidigX[0] += 2;
bHuidigY[0] -= 3;
bHuidigX[1]++;
bHuidigY[1] -= 2;
bHuidigY[2]--;
bHuidigX[3]--;
else if (draai == 1)
draai = 0;
bHuidigX[0] -= 2;
bHuidigY[0] += 3;
bHuidigX[1]--;
bHuidigY[1] += 2;
bHuidigY[2]++;
bHuidigX[3]++;
else if (volgendBlok == 2) //L
if (draai == 0)
draai = 1;
bHuidigX[0]--;
bHuidigY[0]--;
bHuidigY[2]--;
bHuidigX[2]++;
bHuidigX[3] += 2;
bHuidigY[3] -= 2;
draai = 2;
bHuidigX[0]--;
bHuidigY[0]--;
bHuidigX[1] -= 2;
bHuidigY[2]++;
bHuidigX[2]--;
bHuidigX[3];
bHuidigY[3] += 2;
else if (draai == 2)
draai = 3;
bHuidigX[0]++;
bHuidigY[1]--;
bHuidigX[2]--;
bHuidigX[3] -= 2;
bHuidigY[3]++;
else if (draai == 3)
draai = 0;
bHuidigX[0]++;
bHuidigY[0] += 2;
bHuidigY[1]++;
bHuidigX[1] += 2;
bHuidigX[2]++;
bHuidigY[3]--;
else if (volgendBlok == 3)
if (draai == 0)
draai = 1;
bHuidigX[0]--;
bHuidigY[0] += 2;
bHuidigY[1]++;
bHuidigX[2]++;
bHuidigY[3]--;
draai = 2;
bHuidigX[0] -= 2;
bHuidigY[0] -= 2;
bHuidigX[1]--;
bHuidigY[1]--;
bHuidigX[3]++;
bHuidigY[3]--;
draai = 3;
bHuidigX[0]++;
bHuidigY[0]--;
bHuidigX[2]--;
bHuidigY[2]++;
bHuidigY[3] += 2;
draai = 0;
bHuidigX[0] += 2;
bHuidigX[1]++;
bHuidigY[1]--;
bHuidigY[2] -= 2;
bHuidigX[3]--;
bHuidigY[3]--;
else if (volgendBlok == 4)
if (draai == 0)
draai = 1;
bHuidigX[0] -= 2;
bHuidigY[0]++;
bHuidigX[1]--;
bHuidigY[2]++;
bHuidigX[3]++;
draai = 0;
bHuidigX[0] += 2;
bHuidigY[0]--;
bHuidigX[1]++;
bHuidigY[2]--;
bHuidigX[3]--;
else if (volgendBlok == 5)
if (draai == 0)
draai = 1;
bHuidigX[0] -= 2;
bHuidigY[1] += 2;
draai = 0;
bHuidigX[0] += 2;
bHuidigY[1] -= 2;
else if (volgendBlok == 6)
if (draai == 0)
draai = 1;
bHuidigX[0]--;
bHuidigY[0]--;
draai = 2;
bHuidigX[0]++;
bHuidigY[0]++;
bHuidigY[2] -= 2;
draai = 3;
bHuidigY[2] += 2;
bHuidigY[3]--;
bHuidigX[3]++;
draai = 0;
bHuidigX[3]--;
bHuidigY[3]++;
void ledje(int x , int y, boolean aan)//alternative of lc.setLed, so it was easier to work with 2 screens
if (aan == true)
if ( y >= 0 && y <= 7)
lc.setLed(0, y, x, true);
if ( y >= 8 && y <= 15 && aan == true)
y = y - 8;
lc.setLed(1, y, x, true);
else if ( y >= 0 && y <= 7)
lc.setLed(0, y, x, false);
y = y - 8;
lc.setLed(1, y, x, false);
void randomBlok()// generates a random block
volgendBlok = random(-1, 7);
if (volgendBlok == 0) // V
bHuidigX[0] = 4;
bHuidigX[1] = 3;
bHuidigX[2] = 4;
bHuidigX[3] = 3;
bHuidigY[0] = 15;
bHuidigY[1] = 15;
bHuidigY[2] = 14;
bHuidigY[3] = 14;
if (volgendBlok == 1) // I
bHuidigX[0] = 2;
bHuidigX[1] = 3;
bHuidigX[2] = 4;
bHuidigX[3] = 5;
bHuidigY[0] = 15;
bHuidigY[1] = 15;
bHuidigY[2] = 15;
bHuidigY[3] = 15;
if (volgendBlok == 2) // L
bHuidigX[0] = 5;
bHuidigX[1] = 5;
bHuidigX[2] = 4;
bHuidigX[3] = 3;
bHuidigY[0] = 15;
bHuidigY[1] = 14;
bHuidigY[2] = 14;
bHuidigY[3] = 14;
if (volgendBlok == 3) // J
bHuidigX[0] = 5;
bHuidigX[1] = 4;
bHuidigX[2] = 3;
bHuidigX[3] = 3;
bHuidigY[0] = 14;
bHuidigY[1] = 14;
bHuidigY[2] = 14;
bHuidigY[3] = 15;
if (volgendBlok == 4) // Z
bHuidigX[0] = 5;
bHuidigX[1] = 4;
bHuidigX[2] = 4;
bHuidigX[3] = 3;
bHuidigY[0] = 15;
bHuidigY[1] = 15;
bHuidigY[2] = 14;
bHuidigY[3] = 14;
if (volgendBlok == 5) // S
bHuidigX[0] = 5;
bHuidigX[1] = 4;
bHuidigX[2] = 4;
bHuidigX[3] = 3;
bHuidigY[0] = 14;
bHuidigY[1] = 14;
bHuidigY[2] = 15;
bHuidigY[3] = 15;
if (volgendBlok == 6) //T
bHuidigX[0] = 5;
bHuidigX[1] = 4;
bHuidigX[2] = 4;
bHuidigX[3] = 3;
bHuidigY[0] = 14;
bHuidigY[1] = 14;
bHuidigY[2] = 15;
bHuidigY[3] = 14;
void toonBlok()//shows the block that is falling
for ( int i = 0 ; i < 4; i++)
ledje(bHuidigX[i], bHuidigY[i], true);
void verwijderBlok()//turn off the leds of the falling block
ledje(bHuidigX[i], bHuidigY[i], false);
