arduino startup bug
After following the Arduino on gentoo guide to the t, on ./arduio i get
java.lang.UnsatisfiedLinkError: /home/jm/arduino-tar/lib/librxtxSerial.so: /home/jm/arduino-tar/lib/librxtxSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch) thrown while loading gnu.io.RXTXCommDriver
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/jm/arduino-tar/lib/librxtxSerial.so: /home/jm/arduino-tar/lib/librxtxSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1676)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1030)
at gnu.io.CommPortIdentifier.(CommPortIdentifier.java:83)
at processing.app.Editor.populateSerialMenu(Editor.java:903)
at processing.app.Editor.buildToolsMenu(Editor.java:800)
at processing.app.Editor.(Editor.java:190)
at processing.app.Base.(Base.java:149)
at processing.app.Base.main(Base.java:104)
thoughts?
I've also tried the export command used in the generic linux guide.
if i try and build from svn i get
jmf-new-desk linux # export CLASSPATH=/opt/blackdown-jre-1.4.2.03/bin:/opt/blackdown-jre-1.4.2.03/lib/rt.jar
jmf-new-desk linux # ./make.sh
Copying shared and core files...
Copying examples...
Copying dist files...
Building the PDE...
tools/DiscourseFormat.java:6: warning: unmappable character for encoding ASCII
Copyright (c) 2005-06 Ignacio Manuel Gonz?lez Moreta
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
1 warning
Done.
and thats the same whether or not the export line is there.
Are you on a 64-bit version of Linux? If so, you'll need to install RXTX yourself.
Yes I am on 64 bit. :slight_smile:
RXTX has been compiled from source using portage.
$ sudo emerge -vp rxtx
Password:
These are the packages that would be merged, in order:
Calculating dependencies... done!
[ebuild R ] dev-java/rxtx-2.1.7.2-r2 USE="-doc -lfd -source" 0 kB
Total: 1 package (1 reinstall), Size of downloads: 0 kB
Do i need to use the -source flag? Does it have binary components or something?
Hmm, if you installed your own version of RXTX, you should delete the one that comes with Arduino (RXTXcomm.jar and librxtxSerial.so).
