I'm trying to implement a state machine on Arduino using RTC to trigger state changes after specific hours. For this reason, I have implemented a small test state machine code for blinking LED.
In the actual state machine that I have , I intend to put hours as a time gap instead of seconds.
The code doesn't seem to work(Functionally). maybe I'm missing something. Please help.
Also, I'm very new to this. if there's a predefined way to use RTC with State machine please let me know.
I'm very thankful for all the help
#include "RTClib.h"
RTC_DS3231 rtc;
DateTime now = rtc.now();
static uint8_t state;
Serial.begin(57600);
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
pinMode(LED_BUILTIN, OUTPUT);
state = 0;
Serial.println("Setup done");
blink();
void blink(void)
Serial.println("Entered fsm");
DateTime timeLastTransition = rtc.now();
DateTime LED_DELAY = now + TimeSpan(0, 0, 0, 5);
switch (state)
case 0: // toggle the LED
Serial.println("LED Switch");
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
state = 1;
case 1: // wait
Serial.println("Wait");
if (rtc.now() > LED_DELAY) {
LED_DELAY = rtc.now() + TimeSpan(0, 0, 0, 3);
//Serial.println(now.second());
state = 0;
Please describe exactly how it "doesn't work". What is it supposed to do? What does it not do? You did not add any comments to help decipher your code.
Please excuse me for my cumbersome explanation.
here is the code with comments to help explain.
The Code stays at "Toggle state"(case 0) and doesn't go to wait state(case 1). As a result, the LED stays ON and doesn't blink.
I'm using DS3231 RTC with an Arduino Uno.
#include "RTClib.h"
RTC_DS3231 rtc;
if (! rtc.begin()) { // initialising RTC
while (1);
pinMode(LED_BUILTIN, OUTPUT);// Setting LED Output
state = 0;
blink_fsm(); // FSM function code for blinking LED every 5 seconds
void blink_fsm(void)
switch (state)
DateTime LED_DELAY = now + TimeSpan(0, 0, 0, 5); // calculating time span every time it toggles the led.
Serial.println("LED Toggle");
state = 1;
case 1: // wait
if (now > LED_DELAY) { // If time exeeded then go to toggle state
state = 0;
You are making things too complicated using the time span object. RTClib.h has the advantage of providing a "unix" time stamp with now.unixtime().
It is trivial to figure out the number of seconds for your future match.
#include "RTClib.h"
RTC_DS3231 rtc;
while (1);
state = 0;
static unsigned long nextTime = 0;
switch (state)
//DateTime LED_DELAY = now + TimeSpan(0, 0, 0, 5); // calculating time span every time it toggles the led.
nextTime = now.unixtime() +5;
state = 1;
case 1: // wait
if (now.unixtime() > nextTime) { // If time exeeded then go to toggle state
state = 0;
sometimes we use the wrong tool for the wrong purpose
i assume you're trying to figure out how to trigger different actions at various times using the RTC. at least for you example of toggling an LED, there's no need to track state. it would seem more appropriate to have a switch machine where each case is an event.
if (now - nowLst > Timeout) {
nowLst = now;
// do something
this looks very similar to what your code it doing using the RTC
LED_RTC_FSM:42:25: error: no match for 'operator>' (operand types are 'TimeSpan' and 'TimeSpan')
if (now - nowLast > TimeSpan(0, 0, 0, 5)) {
Using library RTClib at version 1.5.0 in folder: G:\OneDrive\Documents\Arduino\libraries\RTClib
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
no match for 'operator>' (operand types are 'TimeSpan' and 'TimeSpan')[code]
