Arduino steering wheel help
Hello, I was trying to make steering wheel and pedals for ETS2 with Arduino, but the only thing i was able to find was clip on youtube in witch the guy made the steering wheel, the accelerator pedal and the brake pedal. But I also want a clutch pedal. So can someone help me with the code. Here is the the video clip link: Arduino UnoJoy Steering Wheel | Gaming steering wheel with Arduino Uno[Steering+Pedals]-ETS2Gameplay - YouTube here is the code:
#include "UnoJoy.h"
void setup(){
setupPins();
setupUnoJoy();
void loop(){
// Always be getting fresh data
dataForController_t controllerData = getControllerData();
setControllerData(controllerData);
void setupPins(void){
// Set all the digital pins as inputs
// with the pull-up enabled, except for the
// two serial line pins
for (int i = 2; i <= 12; i++){
pinMode(i, INPUT);
digitalWrite(i, HIGH);
pinMode(A4, INPUT);
digitalWrite(A4, HIGH);
pinMode(A5, INPUT);
digitalWrite(A5, HIGH);
dataForController_t getControllerData(void){
// Set up a place for our controller data
// Use the getBlankDataForController() function, since
// just declaring a fresh dataForController_t tends
// to get you one filled with junk from other, random
// values that were in those memory locations before
dataForController_t controllerData = getBlankDataForController();
// Since our buttons are all held high and
// pulled low when pressed, we use the "!"
// operator to invert the readings from the pins
controllerData.triangleOn = !digitalRead(2);
controllerData.circleOn = !digitalRead(3);
controllerData.squareOn = !digitalRead(4);
controllerData.crossOn = !digitalRead(5);
controllerData.dpadUpOn = !digitalRead(6);
controllerData.dpadDownOn = !digitalRead(7);
controllerData.dpadLeftOn = !digitalRead(8);
controllerData.dpadRightOn = !digitalRead(9);
controllerData.l1On = !digitalRead(10);
controllerData.r1On = !digitalRead(11);
controllerData.selectOn = !digitalRead(12);
controllerData.startOn = !digitalRead(A4);
controllerData.homeOn = !digitalRead(A5);
// Set the analog sticks
// Since analogRead(pin) returns a 10 bit value,
// we need to perform a bit shift operation to
// lose the 2 least significant bits and get an
// 8 bit number that we can use
controllerData.leftStickX = analogRead(A0) >> 2;
// And return the data!
return controllerData;
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Which controller button acts as a clutch?
Connect the clutch pedal to the pin for that controller button.
