#include "Stepper_28BYJ_48.h"
const int buttonPin1= 2;
int floorState = 3;
Stepper_28BYJ_48 stepper(6, 5, 4, 3);
pinMode(buttonPin1, INPUT);
int buttonState1;
buttonState1 = digitalRead(buttonPin1);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState1 == HIGH) {
if (floorState == 3){
stepper.step(-1);
int floorState = 1;
I need to be able to push a button once and it execute the stepper motor to move like 2 steps down. I have wired everything up and when I press the button it just turns off after I unpress it. Any help.
I would suggest you look at some of the stepper examples in the IDE (File->Examples->Stepper) to get an idea of how to control a stepper motor. Having it move 1 step isn't going to accomplish much.
You also do not need to declare 'floorState' again inside your if() statement. That creates a new variable, separate from your global 'floorState' variable and then it immediately goes out of scope when the if() statement is over. Just assign a value to it 'floorState = 1' without the 'int' part. I'm not really sure what this code will accomplish because once you change the value of 'floorState' the if() statement will never execute again.
