Arduino STILL gives me errors
Ive had a Arduino Uno for 2 and a half weeks now and since yesterday, i couldnt program,
It gives me this error
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa8
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have SEARCHED AND SEARCHED the internet many many times
Here are some details
*Computer recognizes the port
*I can see the Arduino board in device manager
*It compiles in a few seconds
*After 3 minutes of uploading, it displays the error
*The (ON) and(L) were always on since i started getting errors
*When I hold or press or do anything with the reset button, nothing happens
*There is no error with the CH340g
*Loop back test didnt work
*Nothing plugged into TX or RX
*I have deleted and reinstalled the IDE
*I get the same error in all versions
Help me ASAP
(deleted)
I get the same error.
I am using Arduino Uno
Operating system is Windows 10
CH340g USB to seriel
Link to Supplier
Full error message
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4c
option enabled in File -> Preferences.
Double-check that you have the correct port selected in the IDE, under ">Tools >Port".
(I can reproduce your error by selecting the PC's normal serial port in the IDE, instead of the one with an Arduino attached.)
