arduino stop send data(print) to serial monitor
hello guys. i have an arduino uno+wifi shield+nfc and a reed sensor… i want the nfc shield recognise a card and if its correct the password will take a value from reed sensor(if door is open and closed) and sent this value to xively… when i run the code, arduino stops transfer data(stop printing) in serial monitor and the code stucks. This is my code:
#include <SPI.h>
#include <WiFi.h>
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#include <HttpClient.h>
#include <Xively.h>
#define IRQ   (2)
#define RESET (3)  // Not connected by default on the NFC Shield
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
int sensPin = 12;  //pin for reed sensor
int val = 0; // variable for reading the Input Pin status
char ssid[] = "INTERNET"; // your network SSID (name)
int status = WL_IDLE_STATUS;
char xivelyKey[] = "ovE7dyYYkX0v14SbBnNgDa4UKdbaVZmZMhAxgqoqLUynQYsh";
char sensorId[] = "reedsensor";
XivelyDatastream datastreams[] = {XivelyDatastream(sensorId, strlen(sensorId), DATASTREAM_FLOAT),};
XivelyFeed feed(1127679460, datastreams, 1 /* number of datastreams */);
WiFiClient client;
XivelyClient xivelyclient(client);
void setup(void) {
  pinMode(9, OUTPUT); // set pin 9 as output for piezo sound
  pinMode(sensPin, INPUT); // Set Sensor as input
while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid);
    // wait 10 seconds for connection:
    delay(1000 );
  Serial.println("Connected to wifi");
 printWifiStatus();
  Serial.println("Looking for PN532...");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5");
  Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. ");
  Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.');
  Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;                          // Flag to check if there was an error with the PN532
  uint8_t uid[] = {  0, 0, 0, 0, 0, 0, 0     };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  uint8_t currentblock;                     // Counter to keep track of which block we're on
  bool authenticated = false;               // Flag to indicate if the sector is authenticated
  uint8_t data[16];                         // Array to store block data during reads
  uint8_t d[16] = { 0x00, 0x00, 0x03, 0x0C, 0xD1, 0x01, 0x08, 0x55, 0x05, 0x34, 0x34, 0x34, 0x34, 0x34, 0x34, 0x34    };
//array with the default password
  int i;
  int counter= 0 ;  //flag for detection correct password
  pinMode(sensPin, INPUT); // set pin12 as input.
  // Keyb on NDEF and Mifare Classic should be the same
  uint8_t keyuniversal[6] = {  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF     };
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");
   Serial.print(uidLength, DEC);
    Serial.println(" bytes");
   Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    Serial.println("");
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
      // We try to read the data on block that we have wrote. (block=4, sector 1)
      for (currentblock = 4; currentblock < 5; currentblock++)
        // Check if this is a new block so that we can reauthenticate
        if (nfc.mifareclassic_IsFirstBlock(currentblock)) authenticated = false;
        // If the sector hasn't been authenticated, do so first
        if (!authenticated)
          // Starting of a new sector ... try to to authenticate
          Serial.print("------------------------Sector ");
          Serial.print(currentblock/4, DEC);
          Serial.println("-------------------------");
          if (currentblock == 0)
            success = nfc.mifareclassic_AuthenticateBlock (uid, uidLength, currentblock, 1, keyuniversal);
          if (success)
            authenticated = true;
            Serial.println("Authentication error");
        // If we cant authedicate..
        if (!authenticated)
          Serial.print("Block ");
          Serial.print(currentblock, DEC);
          Serial.println(" unable to authenticate");
          // authedicate done... read data from currentblock
          success = nfc.mifareclassic_ReadDataBlock(currentblock, data);
          if (success)
            // Read successful
            if (currentblock < 10)
              Serial.print("  ");
              Serial.print(" ");
            // print data from store array
            nfc.PrintHexChar(data, 16);
            // Failure
            Serial.println(" unable to read this block");
      Serial.println("This isn't a Mifare Classic card");
  int door; //flag for open-close door
    val = digitalRead(sensPin); // read input value for reed sensor
    for (i = 0; i < 16; i++)
      if (data[i] == d[i])
        counter = counter+1;  // flag for authenticate correct password
    if (counter == 16)
      Serial.println("Door is Open");
      beep(100);
      door=1;
      upload(door);
    else{
      Serial.println("Door is Closed");
      beep(50);
      door=0;
       upload(door);
  // Wait a bit before trying again
  Serial.println("\n\nSend a character to run again");
  Serial.flush();
  while (!Serial.available());
  while (Serial.available()) {
    Serial.read();
  Serial.flush();
void beep(unsigned char delayms){  // function to produce sound
  analogWrite(9, 20);      // Almost any value can be used except 0 and 255
  // experiment to get the best tone
  delay(delayms);          // wait for a delayms ms
  analogWrite(9, 0);       // 0 turns it off
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
void upload(int door){
    datastreams[0].setFloat(door);
    Serial.println("Read sensor value ");
    Serial.println(datastreams[0].getFloat());
    Serial.println("Uploading it to Xively");
    int ret = xivelyclient.put(feed, xivelyKey);
    Serial.println("xivelyclient.put returned ");
    Serial.println(ret);
    delay (1000);
do anyone knows the reason of this?
Does your code really look like that? I am certain that it does not. I am equally certain that you couldn't be bothered to read the stickies at the top of the forum that explain how to post here. So, just why should we help you? Go read the stickies, and fix your post, and I'll reconsider.
Meanwhile, think about how much (or little) memory your Arduino has, and how much of that you are using. I'm pretty certain that you'll (eventually) discover that you are using more than you have, which is never a good thing to do.
PaulS: Does your code really look like that? I am certain that it does not. I am equally certain that you couldn't be bothered to read the stickies at the top of the forum that explain how to post here. So, just why should we help you? Go read the stickies, and fix your post, and I'll reconsider.
i modify the post in order to look better. i dont use all memory of arduino. i looked that
How did you check this?
You are using more than you need to.
Serial.print(F(“Found chip PN5”));
Do the same with all the other literal strings.
And what Hackscribble said.
PaulS:
when i load the code in arduino, i take a message that say that the code’s size is 21000bytes, when the max is 32000bytes.
when i load the code in arduino, i take a message that say that the code's size is 21000bytes, when the max is 32000bytes.
The message that you are relying on tells you how much Flash memory you are using. It does not tell you how much SRAM you are using. I still suspect that you are running out of SRAM.
http://playground.arduino.cc/Code/AvailableMemory
