Hello Everybody
Hello Everybody
I'm new in Arduino and I have a problem when I try to communicate VB.net 2017 and Arduino Mega. It's work fine once, but after it read it stop to work. Some times I need to close the program many time, to work again.
This is the code in Arduino
int jqz[]={8,9,10,11,12,13};
int ent[]={2,3,4,5,6,7};
int cont=6;
for(int conta=0;conta<cont;conta++)
{pinMode(jqz[conta],OUTPUT);}
{pinMode(ent[conta],INPUT_PULLUP);}
String jacu = Serial.readStringUntil('\n');
if (jacu.equals("081")){ // Codigo de activacion de Jacuzzi
digitalWrite(jqz[0],HIGH);
else if (jacu.equals("080")){
digitalWrite(jqz[0],LOW);
if (digitalRead(pts[0])){ // Codigo del pin aseo 1
digitalWrite(pts[0],true);
Serial.write("pin0421");}
else{
digitalWrite(pts[0],false);
Serial.write("pin0420");
When I compile it works fine and the serial monitor shows all information fine.
This is the code in VB
Imports ctrlHabitacion
Imports System.Windows.Forms
Imports System.IO.Ports
Imports System.IO
Imports System.Text
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
Timer1.Start()
Inicializa(hab1, 1)
arduino.PortName = "COM8"
arduino.BaudRate = 9600
arduino.DataBits = 8
arduino.Parity = IO.Ports.Parity.None
arduino.StopBits = IO.Ports.StopBits.One
If Not arduino.IsOpen Then
arduino.Open()
End If
End Sub
Private Sub arduino_DataReceived(sender As Object, e As SerialDataReceivedEventArgs) Handles arduino.DataReceived
Dim string1 As String = arduino.ReadExisting()
If string1.Equals("pin020") Then
hab1.bgcolor = Color.Blue
End If
Invoke(subrotinaSTR, string1)
End Sub
Sub tratamentoSTR(ByVal meustring As String)
TextBox2.Text = meustring
End Sub
It works only once and stops the communication and the Arduino turn off all lights.
Thanks for all help
