Arduino stops working when connected to an external power supply
My Arduino works fine when its connected to the computer via the USB but as soon as I disconnect it from the computer, it goes off. I am using a 12V DC adapter (500mA) (center positive) as the external power source. Not sure what is wrong. Please help!
Thanks!
priyankadasgupta:
Thanks!
Well with just the 12V DC adapter plugged into the arduino (no USB connected) take a measurement with your digital multimeter between Vin and ground pins, then take a measurement from the 5V and ground pins. That should tell you the story, if your adapter is bad or the on-board +5vdc voltage regulator is bad.
If you don't have a DMM then your first step is to go buy one, there are very inexpensive ones available and one should not be playing with a arduino without having and knowing how to use one.
Lefty
Resurrecting this as I have the same issue. It works fine on USB but with an external power source the program runs erratically. It's hard to troubleshoot as when I plug the usb back in it's fine. I've got a a good supply and the 5v line is measuring at a steady 5v
nickjb:
What is the voltage and current rating of the supply you are using?
I've got a 12v 2A wall cube and an adjustable bench power supply which is good for 5A but there is only a 40mA draw at 9V. I'm only running the on board LED and a few opto transistors.
