Arduino stops writing serial data to unity - uduino package
hi all, i'm trying to send gyroscope data ( from an mpu 6050) from the arduino to unity, which works for like 1 minute.
It stops working and the 'TX' led switches off. in Unity i get following error
"ReadTimeout. Are you sure something is written in the Serial of the board?
System.TimeoutException: The operation has timed out.
  • at System.IO.Ports.WinSerialStream.Read (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x000a9] in :0*
  • at System.IO.Ports.SerialPort.read_byte () [0x00007] in :0*
  • at System.IO.Ports.SerialPort.ReadTo (System.String value) [0x0003c] in :0*
  • at System.IO.Ports.SerialPort.ReadLine () [0x00000] in :0*
  • at (wrapper remoting-invoke-with-check) System.IO.Ports.SerialPort.ReadLine()*
  • at Uduino.UduinoDevice_DesktopSerial.ReadFromArduinoLoop (System.Boolean forceReading) [0x00042] in C:\Users\brent\test\Assets\Uduino\Scripts\Boards\DesktopSerial\UduinoDevice_DesktopSerial.cs:209*
    UnityEngine.Debug:Log(Object)
    Uduino.Log:Debug(Object, Boolean) (at Assets/Uduino/Scripts/Extra/UduinoDebug.cs:47)
    Uduino.UduinoDevice_DesktopSerial:ReadFromArduinoLoop(Boolean) (at Assets/Uduino/Scripts/Boards/DesktopSerial/UduinoDevice_DesktopSerial.cs:246)
    Uduino.UduinoManager:ReadPorts() (at Assets/Uduino/Scripts/UduinoManager.cs:1504)
    System.Threading.ThreadHelper:ThreadStart()"
i'm using this script for my arduino.
#include "Uduino.h"  // Include Uduino library at the top of the sketch
Uduino uduino("IMU");
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
  Wire.begin();
  Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
  Serial.begin(38400);
  while (!Serial); // wait for Leonardo enumeration, others continue immediately
  mpu.initialize();
  devStatus = mpu.dmpInitialize();
  mpu.setXGyroOffset(54); //++
  mpu.setYGyroOffset(-21); //--
  mpu.setZGyroOffset(5);
  if (devStatus == 0) {
    mpu.setDMPEnabled(true);
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
    // Error
    Serial.println("Error!");
  uduino.update();
  if (uduino.isInit()) {
    if (!dmpReady) {
      Serial.println("IMU not connected.");
      delay(10);
      return;
    int  mpuIntStatus = mpu.getIntStatus();
    fifoCount = mpu.getFIFOCount();
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) { // check if overflow
      mpu.resetFIFO();
    } else if (mpuIntStatus & 0x02) {
      while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
      mpu.getFIFOBytes(fifoBuffer, packetSize);
      fifoCount -= packetSize;
      SendQuaternion();
      //SendEuler();
      //SendYawPitchRoll();
      //SendRealAccel();
      //SendWorldAccel();
void SendQuaternion() {
  mpu.dmpGetQuaternion(&q, fifoBuffer);
  Serial.print("r/");
  Serial.print(q.w, 4); Serial.print("/");
  Serial.print(q.x, 4); Serial.print("/");
  Serial.print(q.y, 4); Serial.print("/");
  Serial.println(q.z, 4);
void SendEuler() {
  // display Euler angles in degrees
  mpu.dmpGetEuler(euler, &q);
  Serial.print(euler[0] * 180 / M_PI); Serial.print("/");
  Serial.print(euler[1] * 180 / M_PI); Serial.print("/");
  Serial.println(euler[2] * 180 / M_PI);
void SendYawPitchRoll() {
  mpu.dmpGetGravity(&gravity, &q);
  mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
  Serial.print(ypr[0] * 180 / M_PI); Serial.print("/");
  Serial.print(ypr[1] * 180 / M_PI); Serial.print("/");
  Serial.println(ypr[2] * 180 / M_PI);
void SendRealAccel() {
  // display real acceleration, adjusted to remove gravity
  mpu.dmpGetAccel(&aa, fifoBuffer);
  mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
  Serial.print("a/");
  Serial.print(aaReal.x); Serial.print("/");
  Serial.print(aaReal.y); Serial.print("/");
  Serial.println(aaReal.z);
void SendWorldAccel() {
  // display initial world-frame acceleration, adjusted to remove gravity
  // and rotated based on known orientation from quaternion
  mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
  Serial.print("a/");
  Serial.print(aaWorld.x); Serial.print("/");
  Serial.print(aaWorld.y); Serial.print("/");
  Serial.println(aaWorld.z);
So the question is, how do i fix the problem where it just stops sending serial data?
anyone has an idea why? i can't seem to find a solution.
(deleted)
Checking hardware revision...
Revision @ user[16][6] = 4D
Resetting memory bank selection to 0...
this is all i get in the serial monitor. i'm using the uduino package. maybe there are some errors in that code?
i fixed it by disconnecting the int(interrupt) wire from the mpu6050
