Hello, I have Controllino Mega with W5100. Everything is basically Arduino mega.
I use direct Ethernet cable to PC to send and recieve data. Controller acts like a server. I use KiTTy to connect. Everything works fine.
However in the even of disconnecting Ethernet cable it hangs and doesn't perform any other actions. (but still counts encoder perfectly). It comes back when I connect the cable.
is there a way to prevent this?
I tried set retransmission timeout but it dosen't seem to have any effect.
I didin't post full code as its over 1000 lines....
//-----setup---//
Ethernet.setRetransmissionTimeout(50);
} // --- end of setup
EthernetClient newClient = server.accept();
if (newClient) {
client = newClient;
client.println("Connected");
client.println("Current = ");
client.println(actualPos);
actualPos = myEnc.read() / (encoderConst / 1000); // convert siganls to mm.
if (abs(actualPos - oldPosition) > 0.2) {
oldPosition = actualPos;
if (client.connected()) {
client.print("Current = ");
client.print(actualPos);
client.print(" Target= ");
client.println(position2reach);
if (client.available() > 0) {
byte thisByte = client.read();
//--- other stuff---
