Arduino substring doesn't work
I have a static method that searches (and returns) into String msg the value between a TAG
this is the code function:
static String genericCutterMessage(String TAG, String msg){
    Serial.print("a-----");
    Serial.println(msg);
    Serial.print("b-----");
    Serial.println(TAG);
    if(msg.indexOf(TAG) >= 0){
        Serial.print("msg ");
        int startTx = msg.indexOf(TAG)+3;
        int endTx = msg.indexOf(TAG,startTx)-2;
        Serial.print("startTx ");
        Serial.println(startTx);
        Serial.print("endTx ");
        Serial.println(endTx);
        String newMsg = msg.substring(startTx,endTx);
        Serial.print("d-----");
        Serial.println(newMsg);
        Serial.println("END");
        Serial.println(newMsg.length());
        return newMsg;
        Serial.println("d-----TAG NOT FOUND");
        return "";
and this is output
a-----[HS][TS]5132[/TS][TO]5000[/TO][/HS]
b-----HS
msg [HS][TS]5132[/TS][TO]5000[/TO][/HS]
startTx 4
endTx 30
d-----
END
0
fake -_-'....go on!  <-- print out of genericCutterMessage
in that case I want return the string between HS tag, so my expected output is
but I don't know why I receive a void string.
to understand how substring works I just followed tutorial on official Arduino site
Any idea?
It's a lot easier for us if you post the entire program so we can run it ourselves.
It's also simpler to create a substring starting at a position to the end of the String, and then insert a NULL at the appropriate position, where the String should end. Determine THAT location (in the substring) AFTER extracting the first substring.
econjack:
thanks for response
uhm It's difficult because it's a part of a Library called to another library, I should paste 6 or 7 files...tomorrow i'll create a little example program with this function
Then you should write code that will do the String parsing successfully on the character String you have, then integrate that back into your other code.
I don't know what the attraction of the string class is, is it really that convenient?
Here's a way of doing it with C style strings, untested obviously :wink:
  char tag[16];
  char msg[64];
  char new_string[64]; // Alternatively malloc this to the exact size of the substring ...
  char *start_tag_p = strstr( msg, tag );
  char *end_tag_p = NULL;
  bool tags_found = false;
  if ( start_tag_p )
    // Found tag! ...
    end_tag_p = strstr( &msg[1], tag );
    if ( end_tag_p )
      // Found the closing tag!
      int new_string_size = ( end_tag_p - start_tag_p );
      memcpy( new_string, start_tag_p, new_string_size );
      new_string[new_string_size + 1] = 0;
      tags_found = true;
  if ( !tags_found )
    // Failed to find your substring ...
