Been using Arduino quite a lot lately and suddenly it is very slow on startup and uploads are hesitating for 20-30 seconds before even starting.
Problem 1:
The Arduino IDE startup is averaging 29 seconds! normally it will load and be ready to go in 5-10 seconds on this system.
Problem 2:
When I click the upload icon, it turns white but compiling doesn't start for 30 seconds or more. and during this time everything in the IDE is frozen. I can't add text, scroll, nothing. At some point long after clicking upload, the icon turns orange and compiling starts and uploads fine.
What can cause this?
I don't think it is my code, but here is a small but complete segment
boolean atHome = true;
boolean remoteCycle = true;
int buttonCount = 0;
int RED = 0xF800;
int zoneCount = 7;
int zonePin[8];
int BACKGROUND = 0;
struct zStruct
int onSecs[6];
zStruct zones[3];
unsigned long tm, lasttm;
zones[0].onSecs[0] = 5;
zones[1].onSecs[0] = 10;
DrawRemotePage();
delay(10);
void DrawRemotePage()
atHome = false;
if (remoteCycle && !atHome)
ClearScreen();
buttonCount = 0;
DrawTime(1);
DrawPumpStatus();
WriteText(3, 90, 60, "Remote Activated", RED);
// Button(2, 190, 180, 90, 35, false, "Stop", RED, FILL, ExitRemote, 0);
// Button(3, 360, 260, false, 100, 35, "Home", BLACK, FILL, ExitRemote, 0);
// start the first zone first time
digitalWrite(zonePin[0], HIGH); // open zone 1 valve
Serial.println("z1 valve open");
PumpOn(); // turn on the pump
lasttm = millis();
tm = lasttm;
while (tm - lasttm <= 5000ul) // 5 second delay
HeartBeat(); // check for touch and time update
tm = millis();
PumpOff(); // turn off the pump
DrawPumpStatus();
lasttm = millis();
tm = lasttm;
while (tm - lasttm <= 4000ul) // 43 second delay
tm = millis();
digitalWrite(zonePin[0], LOW); // close zone 1 valve
Serial.println("z1 valve closed");
ExitRemote(0);
void fillRoundRect(int x, int y, int l, int w, int champfer, int clr) {}
void Rotation(int r) {}
void ExitRemote(int n) {}
void CheckTimeDisplay() {}
void CheckRemote() {}
void Touch() {}
void HeartBeat() {}
void PumpOn()
Serial.println("Pump on");
void PumpOff()
Serial.println("Pump Off");
void ClearScreen() {}
void DrawTime(int n) {}
void DrawPumpStatus() {}
void WriteText(int tSize, int x, int y, String text, int Color) {}
