Hello all,
I was wondering if any user with SuperCollider+Arduino experience could shed a light to the problem I'm having with the code below? Basically, all I'm trying to do is to send data to SC from Arduino when a button is pushed. For some reason it keeps sending the same data, which, in this case, is the one that's set to be sent when the button is NOT pushed.
Here is the Arduino code:
const int buttonPin = 2;
const int ledPin = 13;
int buttonState = 0;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
digitalWrite(ledPin, HIGH);
Serial.print(10);
else {
digitalWrite(ledPin, LOW);
Serial.print(5);
and here's the SC code:
p = SerialPort( "/dev/tty.usbserial-A800eI4B", 115200, crtscts:true);
r = Routine {
loop {
p.next.postln;
1.wait;
}.play;
r.stop; p.close;
The Arduino code is working, i.e. it turns on/off the LED connected to pin 13. However, no matter what the state of the button is, all it sends to SC is "5". Any idea as to what I might be doing wrong?
Thanks so much!
Taylan
