Arduino switch case / if ...else
hey everybody,
I'd like to write an difficult sketch and need help.
I've got 4 LED's in different colours.
in a few weeks I want to integrate 2 sensors via analog pin in my program.
but I don't know how to use "if, else if, else" or "case1", "case2","case3" , "case4".
Now I've tried "if, else if, else"
but it doesn't work.
below u see the code with my "default program"
I'd like to use the 2 new "IR" sensors for stopping
my default programm and to show that a container is empty.
(one IR sensor per container)
so if container1 is empty , program stops and LED red is HiGH
so if container2 is empty , program stops and LED orange is HiGH
until i filled the containers.
#include <Servo.h>
Servo servoLeft; // Define left servo
Servo servoRight; // Define right servo
const int ledPin = 7;
const int tasterPin = 2;
int potPin = A0;    // select the input pin for the potentiometer
int val = 0;       // variable to store the value coming from the sensor
  pinMode(ledPin, OUTPUT);
  pinMode(tasterPin, INPUT);
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(8, OUTPUT);
  servoLeft.attach(10); // Set left servo to digital pin 10
  servoRight.attach(9); // Set right servo to digital pin 9
  if (digitalRead(tasterPin) == LOW) {
    digitalWrite(ledPin, HIGH);
    servoLeft.write(90);
  servoRight.write(90);
  } else{
    digitalWrite(ledPin, LOW);
    digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
    delay(250);              // wait for a second
    digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
    digitalWrite(12, HIGH);   // turn the LED on (HIGH is the voltage level)
    digitalWrite(12, LOW);    // turn the LED off by making the voltage LOW
    digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
    digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
    forward(); // Example: move forward
    delay(500); // Wait 2000 milliseconds (2 seconds)
    reverse();
    turnRight();
    turnLeft();
    stopRobot();
// Motion routines for forward, reverse, turns, and stop
void forward() {
  servoLeft.write(0);
  servoRight.write(180);
void reverse() {
  servoLeft.write(180);
  servoRight.write(0);
void turnRight() {
  servoLeft.write(0);
void turnLeft() {
  servoLeft.write(0);
void stopRobot() {
kindly regards
Don Dennis
You have only one if-else. What is wrong with it? What does it do that you think it should not do, or not do that you think it should do? :slight_smile:
yes it's right I've taken the second else out, because it didn't worked.
I just want to have 4 programs (4 case).
so the first (if) is my Standby program
the second ( else) is my main program
but now I need 2 more
for showing that one of the containers is empty nd stopping the program
kindly regards
Don Dennis
Dtensta:
kindly regards
Don Dennis
You still didn't answer the question. What didn't work? In other words, what happened?
We're not that interested in a sketch that works, simply because you don't need helpt with that :wink: Show us the sketch that did not work so we can advise on what is wrong and help you to solve the issue.
