I have made a code for Ir remote control for appliances but I am not getting output.
Please check it up if it need any correction
* IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 6;
int led = 13;//1FE50AF
int led1 = 12;//1FED827
//int led2 = 11; //1FEF807
////int led3 = 10;//1FE3087
//int led4 = 9;//1FEB04F
boolean previousState=LOW;
boolean previousState1=LOW;
//boolean previousState2=LOW;
//boolean previousState3=LOW;
//boolean previousState4=LOW;
boolean state;
boolean state1;
//boolean state2;
//boolean state3;
//boolean state4;
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
//pinMode(10,OUTPUT);
//pinMode(9,OUTPUT);
// pinMode(8,OUTPUT);
irrecv.enableIRIn();// Start the receiver
if (irrecv.decode(&results))
Serial.println(results.value, HEX);
switch(results.value)
case '0x1FE50AF':
Serial.println("LED ON");
if (previousState == LOW)
{state=HIGH;
digitalWrite(led,state);
previousState=state;}
{state=LOW;
Serial.println("LED Off");
case '0x1FED827':
if (previousState1 == LOW)
{state=HIGH;
digitalWrite(led1,state1);
previousState1=state1;}
{state1=LOW;
Serial.println("LED off");
/*case '0x1FEF807':
if (previousState2 == LOW)
{state2=HIGH;
digitalWrite(led2,state2);
previousState2=state2;}
{state2=LOW;
case '0x1FE3087':
if (previousState3 == LOW)
{state3=HIGH;
digitalWrite(led3,state3);
previousState3=state3;}
{state3=LOW;
case '0x1FEB04F':
if (previousState4 == LOW)
{state4=HIGH;
digitalWrite(led4,state4);
previousState4=state4;}
{state4=LOW;
break;*/
irrecv.resume(); // Receive the next value
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
