Arduino - switch case usage for serial monitor
Hey guys, I am trying to use the switch case to prevent from making several if statement but my issue that I am struggling with is that my mov variable doesn't recognize any of the letters in the cases below.
Any help would be appreciated, thank you very much in advance.
while(Serial.available() > 0 ){
    String com = Serial.readString();
    int mov = Serial.read();
    if(com.indexOf("AUTO") > -1){
      pinOuts = 1; // Type anything else to bring back outputs
      Serial.println("Listening...");
      switch(mov){
        case 'F':
        	Serial.println("Moving Forward...");
        case 'B':
        	Serial.println("Moving Backward...");
        case 'L':
        	Serial.println("Moving Left...");
        case 'R':
        	Serial.println("Moving Right...");
    }    else{
	  pinOuts = 0; // Back to printing all outputs
Your switch variable mov is not. Your case statements are char.
Try char mov instead of int
rickrlh:
Tried that, no luck, goes back to the else statement. Any other suggestions you got?
mov will likely be set to -1, since you've emptied the serial buffer in the previous line.
