Arduino switch with Processing
Hey guys, I have code that uses a button and when pressed will switch on an LED(which will stay on) and then when the button is pressed again, the LED is turned off. I have connected the Arduino and Processing using Standard Firmata successfully and the LED works.
What I want to be able to do is that when the button is pressed, an image will show up in Processing but also stay on the screen, just like the LED. I'm just testing it with shapes for now. This is what I have so far:
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
int buttonPin = 7;
int buttonState = 0;
int buttonPressed = 0;
void setup(){
  size(600, 600);
  println(Arduino.list());
  arduino = new Arduino(this, Arduino.list()[6], 57600);
  arduino.pinMode(buttonPin, arduino.INPUT);
void draw()
  buttonState = arduino.digitalRead(buttonPin);
  if (buttonState == arduino.HIGH && buttonPressed == 0)
    buttonPressed = 1;
    rect(10, 10, 10, 10);
    text("hello", 10, 10);
  if (buttonState == arduino.LOW && buttonPressed == 1)
    buttonPressed = 0;
    rect(50, 50, 10, 10);
Any help would be appreciated!
