Arduino Tank with Collision Avoidance prototype.
Arduino Tank with Collision Avoidance.
This project is a prototype for my CPE301(microcontrollers)
Current Features:
Atmega328 programmed using Arduino
Pololu Trex Jr Motor Controller controlled via serial
Ultrasonic sensor mounted on a servo
When an obstacle is detected in front of the tank, it stops and scans 180 degrees.
It then goes toward direction where the furthest distance is detected.
youtube video
Future features:
Processing program that would display sensor readings.
It will display sonar reading for 180 degrees.
Automatic(using light sensor) and manual control of headlights.
Data would be transmitted using the Xbee
Wireless control using Xbee and any control module.
  • joystick control
  • wii nunchuck control
Mounted Camera for live video feed
RTC for time keeping
GPS
SD card for data logging
Pls feel free ask questions, leave comments, and suggestions.
Thanks,
Bigdinotech
Nice!
That's pretty neat, lucky it didn't wind up down the stairs :slight_smile:
Rob
Hello,
Im very interested in your project, I'll try to do something simillar , the main problem for me is that
I dont know what components to buy for this project, I've got an ARDUINO UNO board , a pair of servo motors and some wheels.
What I need to buy more?
Do you know where to buy them?
thanks for all , the best regards!!
To avoid accidents involving the stairs, you could have a sensor that points forward and down, and if it sees that the floor has given away it will stop to investigate further before taking a tumble
silvertrun:
Hello,
You will need some DC motors and some way to mount them. You will also need some motor controllers or an H-bridge.
As for the other components it really depends on what you want to do.
For simple collision avoidance, the most common ones are IR or ultrasonic sensors.
If you want to control it wirelessly, you can get an RF module or XBEEs.
I normally get most my parts either from adafruit.com or sparkfun.com
Project Update!!!
Added/finished some features to project.
Mobile Data Logger:
Logs Temperature and Light Level
Two modes of operation:
Automated - Moves on its own avoiding obstacle while sending sensor data. Also sends sonar data
Manual - Manual control using key presses or button clicks
Xbee:
Used Xbee for comunications.
Base - Transmits control data to mobile data logger
mobile data logger - transmits sensor data to base
Processing:
Visually shows sensor data
Logs data to a file
Shows Signal Strength
Youtube video
Arduino Code:
//Code on the actual mobile data logger
//Dino Tinitigan
//Controller
#include <NewSoftSerial.h>
#include <Servo.h>
NewSoftSerial mySerial(2, 3); //Serial Port for Motor Controller
Servo myservo;
//------------------definitions for pololu motor controller---------------
//Trex Jr Motor Controller
#define brkM1  192  //followed by 1 data byte
#define revM1  193  //followed by 1 data byte
#define fwdM1  194  //followed by 1 data byte
#define brkM2  200  //followed by 1 data byte
#define revM2  201  //followed by 1 data byte
#define fwdM2  202  //followed by 1 data byte
#define brkM   208  //followed by 2 data bytes
#define revM   213  //followed by 2 data bytes
#define fwdM   218  //followed by 2 data bytes
#define fM1rM2 214  //followed by 2 data bytes
#define rM1fM2 217  //followed by 2 data bytes
byte incoming;
byte checksum;
byte prevC;
int pos;
int at = 0;
int lTot;
int rTot;
int temp;
float d;
int hazard = 0;
float vRef = 4.80;
byte type;
int v1 = 100; //speed variables
int v2 = 50; //speed variables
  Serial.begin(19200);  //connected to XBee
  mySerial.begin(19200); //connected to motor controller
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(2, INPUT);
  pinMode(3, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  myservo.write(90);
  if(at==1)
    automated();
  //-------------movement commands----------------------//
  if(Serial.available())
   incoming = Serial.read();
   if(incoming == 'X')
     brake(64);
     at = 0; //turn automated off
   else if(incoming == 'W')
     if(prevC!=incoming)
       forward(v1);
     prevC = 'W';
   else if(incoming == 'S')
     if(prevC!=incoming)
       reverse(v1);
     prevC = 'S';
   else if(incoming == 'A')
     if(prevC!=incoming)
       hardLeft(v1);
     prevC = 'A';
   else if(incoming == 'D')
     if(prevC!=incoming)
       hardRight(v1);
     prevC = 'D';
   else if(incoming == 'Q')
     if(prevC!=incoming)
       forwardLeft(v1, v2);
     prevC = 'Q';
   else if(incoming == 'E')
     if(prevC!=incoming)
       forwardRight(v1, v2);
     prevC = 'E';
   else if(incoming == 'Z')
     if(prevC!=incoming)
       reverseLeft(v1, v2);
     prevC = 'Z';
   else if(incoming == 'C')
     if(prevC!=incoming)
       reverseRight(v1, v2);
     prevC = 'C';
   else if(incoming == 'U')
     prevC = 'U';
     at = 1; //turn automated ON
     brake(64);
   Serial.flush(); //flush the serial port
 //-------------------Sensor Data----------------------//
   sendLight();
   sendTemp();
   //delay(50); //delay to prevent overflowing the serial buffer
void forward(int spd)
  mySerial.print(fwdM, BYTE);
  mySerial.print(spd, BYTE);
void reverse(int spd)
  mySerial.print(revM, BYTE);
void brake(int spd)
  mySerial.print(brkM, BYTE);
void forwardRight(int spd1, int spd2)
  mySerial.print(spd1, BYTE);
  mySerial.print(spd2, BYTE);
void forwardLeft(int spd1, int spd2)
void reverseRight(int spd1, int spd2)
void reverseLeft(int spd1, int spd2)
void hardRight(int spd)
  mySerial.print(fM1rM2, BYTE);
void hardLeft(int spd)
  mySerial.print(rM1fM2, BYTE);
void automated()  //Automated mode
   hazard = 0; //default value
   forward(v1);
   int tot = 0;
   for(int i = 0; i<5; i++) //get 5 readings and average it
     temp = getRange();
     tot  = tot + temp;
     delay(50); //delay to let sensor update with new data
   temp = tot/5;
   if(temp <= 8) //closer than 8 inches
     sweep();
     hazard = 1; //hazard found
   if(hazard==1)
     if(lTot > rTot)
       boolean turning = true;
       hardLeft(v1);
       delay(1000); //initial turn delay
       while(turning)
         int dt = getRange();
         if(dt >= 16)
           //16 inch clearance found
           forward(v1);
           turning = false;
       hardRight(v1);
       while(turning)
         if(dt >= 16)
           forward(v1);
           turning = false;
     }//end of else
   }//end of if
}//end of automated
void sweep()
  lTot = 0;
  rTot = 0;
  brake(64); //make sure vehicle is stoppped before doing a sweep
  for(pos = 0; pos < 180; pos += 2)  //sweeps from 0 degrees to 180 degrees
    myservo.write(pos);
    delay(50);
    temp = getRange();
    if(pos>90)
      lTot = lTot + temp;
      rTot = rTot + temp;
    //transmit data
    type = 128; //128=>sonar data
    checksum = temp + pos;
    Serial.write(255); //header byte
    Serial.write(type);
    Serial.write(temp); //distance byte
    Serial.write(pos); //angle byte
    Serial.write(checksum); //checksum byte
  myservo.write(90);  //return to middle;
  Serial.flush(); //flush serial port
int getRange()
  //reads analog value from port and returns into a converted value in inches
  int z = analogRead(0);
  d = z*vRef*1000;
  d = d/1024;
  d = d/9.8;
  z = (int)d;
  return z;
void headLightsOn()
  digitalWrite(13, HIGH);
  digitalWrite(12, HIGH);
void headLightsOff()
  digitalWrite(13, LOW);
  digitalWrite(12, LOW);
int getTemp()
  int totalT = 0;
  double temp1;
  int prevT;
  //calculate initial value
  temp1 = analogRead(2);
  temp1 = temp1*1000; //millivolts factor
  temp1 = temp1/1024; //10-bit range
  temp1 = temp1*vRef; //vref
  temp1 = (temp1-500)/10; //calculate temperature in Celcius
  prevT = (int)temp1;
  for(int i = 0; i<10; i++) //get an average of 50 readings to fix noise issue
    if(temp1 >= (prevT+5)) //huge fluctuation
      temp1 = prevT; //keep last value and discard invalid value
    prevT = temp1;
    totalT = totalT + temp1;
    delay(5);
  totalT = totalT/10;
  return totalT;
void sendTemp()
  type = 89;
  int t1 = getTemp();
  checksum = t1;
  Serial.write(type); //ID byte
  Serial.write(t1); //data byte
void sendLight()
  int lightLevel = analogRead(1);
  if(lightLevel <600)
    headLightsOn();
    headLightsOff();
  type = 23;
  lightLevel = lightLevel/4; //make the data fit into a byte
  checksum = lightLevel + type;
  Serial.write(lightLevel); //data byte
