Looking to get more understanding of the overall logic behind a program.
I am building a CAN bus communication device to be able to communicate with my vehicle.
I have done several readers ect but this new one is a little more advanced and needs to filter CAN data.
Steps: 1) Read serial integer input. IF #1 do routine, IF #2 do a second routine ect.
Step: 2) Inside IF statement for serial input, write the first CAN message to start said routine.
I have made it this far no problem. But now I need to understand how to read the CAN bus for the specific response right after I send the start routine command.
Ex: I send ID: 0x0750 Data: 00 00 00 00 00 00 00 00
Get response ID: 0x0758 Data:11 11 11 11 11 11 11 11
After sending a message, I need to look for, and print, the response (data in ID 0x0758) as fast as I can.
My issue as I understand is CAN is FIFO and basically you need to continually be reading the entire bus row by row in a loop. Not sure if trying to read the Bus inside my integer IF statement is a good idea or if the read has to be part of the main loop always running with no delays ect.
I have been reading about CAN Mailboxs but am not sure if this technique is best.
Basically looking for a way to say Read the CAN Bus as this specific ID only, right after I write a message to it.
Any thoughts, advice, to help me understand the best logic for doing this?
