Arduino Telnet Client print when Button pressed
Hello everyone,
I am looking for a solution to send different commands over the Arduino Telnet Client by pressing the associated Button to control an external device over Telnet.
I started with the example https://www.arduino.cc/en/Tutorial/TelnetClient and it works well when I type in a Command and push Send in the Serial Monitor.
But now I would like to have for example 4 Buttons.
If I press Button 1, then Client.print ,,Button1Pressed"
If I press Button 2, then Client.print ,,Button2Pressed"
Can somewone say me how I can Integrate it in the Sketch.
Thanks in advance!
start with https://www.arduino.cc/en/Tutorial/InputPullupSerial
Hello Juraj,
thank you for your suggestion.
I have build up also the example, but my problem is to integrate the different Sketches.
The problem is that i am complete new with arduino. But I need a solution for a project, but I do not have enough time to become a perfect Arduino user.
I hope someone can give me Almost a finished solution ;D
Thank's a lot!
it is not about arduino. you can't write a sketch if you didn't learn programming. not the language, but the concepts of programming - algorithms and data types
