Hi all,
I have a technical difficulty with one project i am currently running.
The initial setup is relatively simple :
I have an Arduino Pro Mini connected to a DS18B20 Temp Sensor and a TX RF 433Mhz Module.
The temp sensor is measuring the temp, arduino is sending it over the air. Then i have a RX RF 433Mhz Module on a Raspberry Pi that sniffs the data and store whatever he receives in a .txt file.
The program i use to send the data is derived from the RCSwitch code (in theory made for doing Remote stuff...)
Here is the full setup :
The wiring and the code : i-build-stuff: [Wireless Room Temperature Monitoring System] Temperature sensing with DS18B20 sensor and Arduino Pro Mini
How i send and receive between Arduino and Raspberry Pi : i-build-stuff: [Wireless Room Temperature Monitoring System] Sending Temperature values to the Raspberry Pi and store it in a .txt file
My problem is the following :
I plan to have more than one Wireless temperature sensor in my place so i need to be able to differentiate a value sent by the outside sensor.
As of now the code i use allows me to send an INT only ... i can't seem to be able to append any STRING.
Maybe i can try to append a "unique" number in front of the temp value ... but i do not know how to do it.
Does anyone have any suggestion for me ? Maybe i am using the wrong code to send the data over ... or maybe i am dumb !
