Arduino Temperature Controller
How do I code an Arduino wherein the temperature Sensor will tell the Solenoid Valve how slow or fast the flow of water will go. :slight_smile: thanks for the help.
Which Arduino? Which temperature sensor? Which solenoid valve (link please)?
What have you done so far?
The more information that you provide the more, faster and better help you will get.
solenoid valve is on or off, fast and slow are not something you control, just on or off.
read the temperature from your sensor.
if the temperature is higher than X degrees
set your solenoid to HIGH
if your temperture is lower than ( X-5) degrees
set your solenoid to LOW
since you cannot turn on and off at the same time, the (X-5) gives you a window of a dead band where it is lower than the turn ON point, but even a bit lower than that.
temperature, as with almost everything you measure, will bounce up and down a bit.
you do not want to have your output bouncing up and down.
the gap, or dead band, or hysteresis, is that place you allow the sensor to drift without doing anything.
since you did not tell us what you wanted to do, or how you were doing it, or what you were using, we cannot offer much more than some general ideas.
