Hi, we are develop a project with arduino for monitor temperature and presence. We have to reach the state by web and with SNMP polling, also save some data in a SD card.
We use Arduino Uno + Eth Shield (SD), an analog thermistor and one PIR.
The task are:
client webpage build on arduino showing the temperature and if there's a precence
write on SD card when is disclose a presence
response to SNMP request with the temperature state and other some parameter
The sketch seem to work fine, but it crash a lot of time, and we doesn't know if is a memory problem, or other software issue.
Have someone find other similar problem and could help us?
#include <Streaming.h> // Include the Streaming library
#include <Ethernet.h> // Include the Ethernet library
#include <Flash.h>
#include <SPI.h>
#include <MemoryFree.h>
#include <Agentuino.h>
#include <SD.h>
#include <Time.h>
#include <Udp.h>
Ethernet.begin(mac, ip);
//GESTIONE TIMER LOG
Udp.begin(localPort);
setSyncProvider(getNtpTime);
while(timeStatus()== timeNotSet)
//GESTIONE SD
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
pinMode(PinMov,INPUT);
// api_status = Agentuino.begin();
// Agentuino.onPduReceive(pduReceived);
return;
int Presenza;
char data_presenza;
String h,m,s;
double Limite = 27;
// listen/handle for incoming SNMP requests
// Agentuino.listen();
// sysUpTime - The time (in hundredths of a second) since
// the network management portion of the system was last
// re-initialized.
if ( millis() - prevMillis > 1000 )
// increment previous milliseconds
prevMillis += 1000;
// increment up-time counter
locUpTime += 100;
Temperatura = int(Thermister(analogRead(Pinmode)));
File dataFile = SD.open("Temp.log", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print("Temperatura: ");
dataFile.println(Temperatura);
Serial.println(Temperatura);
dataFile.close();
// if the file isn't open, pop up an error:
else {
Serial.println("Errore apertura file!!");
if (digitalRead(8)== 1)
Presenza=1;
Time = now();
// digitalClockDisplay();
File data = SD.open("Presenze.log", FILE_WRITE);
if (data)
h=String (hour());
m=String (minute());
s=String(second());
String date = h+":"+m+":"+s;
Serial.println(date);
data.println("C'è stata una presenza!");
data.close();
Serial.println("No presenza");
Presenza=0;
//PAGINA WEB HTTP
Client client = server.available();
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available())
char c = client.read();
readString.concat(c); //store characters to string
// COSTRUZIONE PAGINA HTML
client.println("Content-Type: text/html");
client.println();
// inizializzo pagina (da togliere se uso ajax)
client.print("<html><head><title>ARDUINO Controllo Ambientale Meucci2</title><meta http-equiv='Content-Type' content='text/html; charset=iso-8859-1' ></head><body>");
//inizai il body
client.println("<div style='width:360px; height:520px;'>"); //risoluzione per nokia 5800 640x360
client.println("<H3>STATUS SENSORI DC MEUCCI-2</H3><hr />"); //Scrive sul browser il valore del termistore
client.println("<p>TEMPERATURA = ");
client.print(Temperatura);
client.println(" C
</p>");
client.print("ALLARME PRESENZA: ");
if (Presenza== 1){
client.print("<font style='color:red'>HIGH</font>");
client.print("LOW");
client.println("
//Scrive sul browser il valore della fotoresistenza
// firma
client.println("<hr />");
client.print("<h4>Visita <a href='http://www.infracom.it.it' target='_blank' />www.infracom.it</a></h4>");
// chiudo il div
client.println("</div>");
// chiudo pagina da togliere se uso ajax
client.println("</body></html>");
// pulisco la stringa per la successiva lettura
readString="";
//fermo il client
client.stop();
//if c == /n
// if client available
// while client connesso
// listen for incoming Ethernet connections:
To check and see if you are running out of memory distribute some "Serial.println(freeMemory());" in the code. I've found I need a couple of hundred bytes free or the device dies erratically. If you are running out of memory, use PSTR to handle strings and get some back. I noticed you already include MemoryFree.h.
strcpy_P(buffer,PSTR("string text goes in here"));
Serial.println(buffer);
Yes, there is a MemoryFree library, google for the latest location. I honestly can't remember where I got it a few months ago. It's simple and works well.
