the Adruino Testsuite ,from the examples, give me the following error:
ATS_Genaral:
info.MANUFACTURER = Arduino
info.CPU-NAME = ATmega328P
info.GCC-Version = 4.3.5
info.AVR-LibC-Ver = 1.6.8
info.Compiled-date = Apr 29 2011
info.Test-Suite-Name = general
info.Free-memory = 1394 bytes
DigitalReadWrite_02 (helper pin=03) ... FAIL
DigitalReadWrite_03 (helper pin=02) ... FAIL
DigitalReadWrite_04 (helper pin=05) ... FAIL
DigitalReadWrite_05 (helper pin=04) ... FAIL
DigitalReadWrite_06 (helper pin=07) ... FAIL
DigitalReadWrite_07 (helper pin=06) ... FAIL
DigitalReadWrite_08 (helper pin=09) ... FAIL
DigitalReadWrite_09 (helper pin=08) ... FAIL
DigitalReadWrite_10 (helper pin=11) ... FAIL
DigitalReadWrite_11 (helper pin=10) ... FAIL
DigitalReadWrite_12 (helper pin=13) ... FAIL
DigitalReadWrite_13 (helper pin=12) ... FAIL
DigitalReadWrite_14 (helper pin=15) ... FAIL
DigitalReadWrite_15 (helper pin=14) ... FAIL
DigitalReadWrite_16 (helper pin=17) ... FAIL
DigitalReadWrite_17 (helper pin=16) ... FAIL
DigitalReadWrite_18 (helper pin=19) ... FAIL
DigitalReadWrite_19 (helper pin=18) ... FAIL
PWMoutput_03 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_05 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_06 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_09 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_10 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_11 (PWM=128 100% LOW 0% HIGH) ... FAIL
AnalogInput_00 (Low= 0 High= 31 helper pin=15) ... FAIL
AnalogInput_01 (Low=1017 High=1017 helper pin=14) ... FAIL
AnalogInput_02 (Low= 603 High= 660 helper pin=17) ... FAIL
AnalogInput_03 (Low=1019 High=1020 helper pin=16) ... FAIL
AnalogInput_04 (Low= 535 High= 602 helper pin=19) ... FAIL
AnalogInput_05 (Low=1023 High=1023 helper pin=18) ... FAIL
EEPROM_byte_rw (addr= 0x0108) ... ok
EEPROM_word_rw (addr= 0x00ED) ... ok
EEPROM_dword_rw (addr= 0x002F) ... ok
Memory Usage ... ok
Ran 34 tests in 6.761s
FAILED (failures=30)
______________________________________________________________________
ATS_StringIndexOfMemory:
info.Test-Suite-Name = String Memory Test
info.Free-memory = 604 bytes
The index of > in the string <HTML><HEAD><BODY> is 5
The index of the second > in the string <HTML><HEAD><BODY> is 11
The index of the body tag in the string <HTML><HEAD><BODY> is 12
Memory Usage (lost 547 bytes) ... FAIL
Ran 1 tests in 1.573s
FAILED (failures=1)
ATS_StringTest:
info.Test-Suite-Name = Test of String Library
info.Free-memory = 106 bytes
1. Adding a constant integer to a string: ... ok
2. Adding a constant long interger to a string ... FAIL
3. Adding a constant character to a string ... FAIL
4. Adding a constant string variable to a string ... FAIL
5. Adding a constant long interger to a string ... FAIL
6. Two strings equal ... ok
7. Two strings not equal ... ok
8. Two strings not equal [case sensitivity matters] ... ok
9. Equals() method equals ... ok
10. Not equals() method equals ... ok
11. EqualsIgnoreCase() method equals ... ok
12. A numeric string compared to the number it represents ... ok
13. Two numeric strings compared ... ok
18. The compareTo() operator also allows you to compare strings... ok
19. The compareTo() String with integers ... FAIL
20. The compareTo() compare strings with appended integers... FAIL
21. Adding string to string += ... ok
22. The compareTo() compare strings with appended integers... ok
Ran 18 tests in 2.592s
FAILED (failures=6)
ATS_ToneTest:
info.Test-Suite-Name = ToneTest
info.Free-memory = 1246 bytes
ToneTest.02 (out freq= 1111 measured freq= 0 err= 100%) ... FAIL
ToneTest.03 (out freq= 263 measured freq= 0 err= 100%) ... FAIL
ToneTest.04 (out freq= 750 measured freq= 0 err= 100%) ... FAIL
ToneTest.05 (out freq= 282 measured freq= 0 err= 100%) ... FAIL
ToneTest.06 (out freq= 293 measured freq= 0 err= 100%) ... FAIL
ToneTest.07 (out freq= 1415 measured freq= 0 err= 100%) ... FAIL
ToneTest.08 (out freq= 478 measured freq= 0 err= 100%) ... FAIL
ToneTest.09 (out freq= 207 measured freq= 0 err= 100%) ... FAIL
ToneTest.10 (out freq= 1692 measured freq= 0 err= 100%) ... FAIL
ToneTest.11 (out freq= 1383 measured freq= 0 err= 100%) ... FAIL
ToneTest.12 (out freq= 613 measured freq= 0 err= 100%) ... FAIL
ToneTest.13 (out freq= 1930 measured freq= 0 err= 100%) ... FAIL
ToneTest.14 (out freq= 845 measured freq= 0 err= 100%) ... FAIL
ToneTest.15 (out freq= 314 measured freq= 0 err= 100%) ... FAIL
ToneTest.16 (out freq= 1876 measured freq= 0 err= 100%) ... FAIL
ToneTest.17 (out freq= 1769 measured freq= 0 err= 100%) ... FAIL
ToneTest.18 (out freq= 1772 measured freq= 0 err= 100%) ... FAIL
ToneTest.19 (out freq= 1276 measured freq= 0 err= 100%) ... FAIL
ToneTesDurationt.02 (durationTime = 0/1000 freq err= 100%)... FAIL
ToneTesDurationt.07 (durationTime = 0/1000 freq err= 100%)... FAIL
ToneTesDurationt.12 (durationTime = 0/1000 freq err= 100%)... FAIL
ToneTesDurationt.17 (durationTime = 0/1000 freq err= 100%)... FAIL
Memory Usage ... ok
Ran 23 tests in 28.913s
FAILED (failures=22)
Is this normal? During the tests, nothing was connected (on the Arduino 2009).
