Hello,
I have been testing code for my TF-Mini. It currently works and shows on the Serial.Plotter.
I was wondering if i can then use this Serial.Plotter to room map in 2 dimensions?
So that when i move around the room with the tf-mini it maps accordingly.
Any help is appreciated.
#include <SoftwareSerial.h> //header file of software serial port
#include <Servo.h>
#define TRIGGER_PIN A1
#define ECHO_PIN A0
#define MAX_DISTANCE 400
const int LS = A2; //set Left Sensor to digital pin 2
const int RS = A3; //set Right Sensor to digital pin 3
Servo servo;
SoftwareSerial Serial1(8, 9); //define software serial port name as Serial1 and define pin8 as RX and pin9 as TX
SoftwareSerial mySerial(11, 10);
//Ultrasonic Variables
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
boolean object;
float time = 0;
long duration, cm;
int distance = 0; //set distance value to 0
int pos = 0;
// Motor A connections
int enA = 7;
int in1 = 5;
int in2 = 6;
// Motor B connections
int enB = 2;
int in3 = 3;
int in4 = 4;
// Lidar Variables
int dist; //actual distance measurements of LiDAR
int strength; //signal strength of LiDAR
int check; //save check value
int i;
int uart[11]; //save data measured by LiDAR
const int HEADER = 0x59; //frame header of data package
mySerial.begin(9600);
Serial1.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
servo.attach(12);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(TRIGGER_PIN, OUTPUT); //sets TRIGGER_PIN to OUTPUT
pinMode(ECHO_PIN, INPUT); //sets ECHO_PIN to INPUT
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
void Forward()
digitalWrite(in1, HIGH);
digitalWrite(in3, HIGH);
analogWrite(enA, 150); //enA speed variable - Right Wheel
analogWrite(enB, 150); //enB speed variable - Left Wheel
void TurnLeft()
digitalWrite(in4, HIGH);
analogWrite(enA, 100); //enA speed variable - Right Wheel
analogWrite(enB, 100); //enB speed variable - Left Wheel
void TurnRight()
void Stop()
digitalWrite(in2, HIGH);
//Lidar Code - TF-Mini
if (Serial1.available()) //check if serial port has data input
if (Serial1.read() == HEADER) //assess data package frame header 0x59
uart[0] = HEADER;
uart[1] = HEADER;
for (i = 2; i < 9; i++) //save data in array
uart[i] = Serial1.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)) //verify the received data as per protocol
int angle = 0;
dist = uart[2] + uart[3] * 256; //calculate distance value
strength = uart[4] + uart[5] * 256; //calculate signal strength value
Serial.print("distance = ");
Serial.print(dist); //output measure distance value of LiDAR
Serial.print('\t');
Serial.print("strength = ");
Serial.print(strength); //output signal strength value
Serial.print('\n');
//Bluetooth Module - HC-05
mySerial.println(dist);
//Subroutine Statements
if ((digitalRead(RS) == 0) && (digitalRead(LS) == 0)) {
Forward(); //if statement for forward
if ((digitalRead(RS) == 0) && (digitalRead(LS) == 1)) {
TurnRight(); //if statement for TurnRight
if ((digitalRead(RS) == 1) && (digitalRead(LS) == 0)) {
TurnLeft(); //if statement for TurnLeft
if ((digitalRead(RS) == 1) && (digitalRead(LS) == 1)) {
Stop(); //if statement for Stop
if (distance < 25){
Stop(); //if statement for Ultrasonic Stop
