CrossRoads:
Couple of nit comments:
Why int here and not byte?
const int BUTTON_PIN = 7;
Same with state, prevState, pin. variables that are only 0/1 don't need to be ints, and there are no pins above 255, so they also don't need to be int. You have int's all thru the example that could be byte instead.
I use an int because the pinMode and digitalWrite functions take ints.
In justification: the arduino is a 16-bit processor, so it's all just one bus read anyway. Using ints means that things wind up on even byte boundaries, which might be a good thing (It was a thing back in the day on x86 processors). If your sketch is just one byte short of being able to fit into ram, you probably need a mega.
If you have big arrays then that's a different story, agreed.
CrossRoads:
I like the explanation you provide. This looks like stuff I just code inline in my sketches.
Absolutely. Classes just provide a way of organising your code. The difference between using classes and not using them is like the diference between using block-structured code and using gotos. Block-structured languages happened because people started noticing that coders followed consistent idioms when writing loops, ifs, and all the rest. Classes are the same - they are formal support in the language for things that people are doing anyway.
CrossRoads:
MrsCrsossRoads ridicules me for it, but I figure I'm saving processing time by not jumping back & forth in & out of functions,
Yeah, there are inefficiencies doing it this way because class methods can't assume an absolute location for your variables. In fact, the memory address of the instance is passed invisibly to every method. If you need hand-tuned speed, working this way won't do the job. But, it's not that bad. At a guess, the instance address goes into a register, and the generated code uses register-relative addresses.
If microseconds matter then this pattern is not suitable, and for some microcontroller projects, microseconds do matter. The really high-speed arduino stuff with be working with interrupts and ports. Even then, however, it can make sense to use classes to do things that operate at human speed - manual switches, blinky lights.
The main benefit is that you can code up complex things that mostly work first time, without burning out your brain keeping track of all the possible permutations of state in your system.
