Arduino theremin, ref. book: Arduino Music and Audio Projects by Mike Cook
Hello all,
I'm the happy owner of the book Arduino Music and Audio Projects by Mike Cook.
I am experimenting with the theremin in chapter 5.
The code comments in the book say that it spans 6 octaves. However, mine does not seem to span that much. I am using potentiometers instead of the distance sensor in the original project. I plan to add distance sensors later, but wanted to keep things simple for now until I see that it works.
I output the MIDI signal to a Yamaha PSR-225GM, and it basically works, both with the (modified) theremin sketch and with the simple "MIDI Note Out" sketch (after fixing i typo in the downloaded code (baud rate was wrong).
My problem here, is that as far as I can hear the span is far from six octaves. So I'd like to try setting it for a different span. I do that by amending the controlSend statement in the setup section from "controlSend(6,72)" to "controlSend(6,24)" (for two octaves).
Rotating the pots does change the pitch and volume, respectively, but not to six octaves (as far as I can tell by comparing to playing the same voice directly on the keyboard of the Yamaha).
I can't hear much of a difference, so I wonder if there is something wrong somewhere in the code. I have tried to look up the MIDI standard for setting the number of octaves, but I did not have much luck with that.
So, does anyone of you have experince with this? Do you have any suggestions for troubleshooting?'
Full code is below.
Best regards,
Lars
/* Theremin  - Mike Cook
 *  LM 2019-09-23: modifying to use potentiometers instead of infrared sensors.
 *  Middle pin of pots is connected to pins A0 and A3, respectively.
 *  Other pins are connected to +5V and GND.
boolean playing = false;
const byte channel = 0;
const byte baseNote = 72;
void setup(){
  Serial.begin(31250); // MIDI baud rate
  // analogReference(EXTERNAL);
  controlSend(0, 0); // set bank 0 MSB
  controlSend(32, 0); // set bank 0 LSB
   programChange(52); // send voice number
    // programChange(52); // send voice number
  // set up Pitch bend sensitivity
  controlSend(101, 0);
  controlSend(100, 0);
  controlSend(6,72); // set to 6 octaves
   // controlSend(6,24); // set to 2 octaves
  controlSend(38, 0); // and zero cents
void loop(){
  int av1 = 1027 - analogRead(0);
  int av2 = 1027 - analogRead(3);
  if(av1 <870 && av2 < 870){
     if(!playing)noteOn();
     else {
          trackNote(av2,av1);
  else {
    if(playing) noteOff();
void noteOff(){
  playing= false;
  // note off + sustain off
  noteSend(0x80,baseNote,127);
  controlSend(64, 0);
void noteOn(){
 // note on + sustain on
  noteSend(0x90,baseNote,127);
  controlSend(64, 127);
  playing = true;
int trackNote(int freq, int volume){
  int pb = 0x2000 - (435 - freq);
  sendPB(pb);
  int vel = volume>> 3;
   controlSend(7, vel);
 void noteSend(byte cmd, byte data1, byte data2) {
  cmd = cmd | channel;
  Serial.write(cmd);
  Serial.write(data1);
  Serial.write(data2);
void controlSend(byte CCnumber, byte CCdata) {
  byte CCchannel = channel | 0xB0; // convert to Controller message
  Serial.write(CCchannel);
  Serial.write(CCnumber);
  Serial.write(CCdata);
void sendPB(int pb){ // send pitch bend message
  Serial.write( (byte)0xE0 | channel);
  Serial.write( pb & (byte)0x7f);
  Serial.write( (pb>>7) & (byte)0x7f);
void programChange(byte voice){
  Serial.write((byte)0xC0 | channel);
  Serial.write(voice);
logarithmic or linear taper pots?
It looks like your keyboard / MIDI sound generator is not capable of responding correctly to the commands to set the size of each step for the pitch bend command. This might be the case if the sound is generated by playing an audio sample as opposed to synthesising the sound. There is only so much pitch pulling you can get with an audio sample of a fixed size and sample rate.
To get a sample capable of being pulled that far the sample file's size would need to be much larger than it otherwise would need to be.
Have you tried this on other MIDI sound generating modules?
Thanks for your positive comments on my book. I did put a lot of work into it.
MarkT:
Hi Mark,
The thought occurred to me, but I'm away from my hardware now, so could not check. In any case I think it should be the same at the extremes - I think, but will check.
Grumpy_Mike:
Thank you, Mike,
I did not try any other sound generating modules, but the Yamaha spans five octaves on the keyboard itself, so I would assume that it can span at least that much, MIDI wise, too. But then I may be wrong. The keyboard is quite old, so they may well have chosen to use samples instead of synthesising the sounds.
I'll see if I can find (or build) another MIDI module, or else try something else.
Thank you again for writing the book.
Best regards,
Lars
Larsm:
But the keyboard does not have any natural pitch bend capability. So unfortunately it is quite possible that the implementation of incoming MIDI pitch bend commands is limited...some keyboards only allow a fixed +/-2 semitones pitch bend. I used to have a different old Yamaha keyboard and that was restricted like that.
Perhaps you could try it with a software module on PC. There are plenty of free VSTs that that allow wide range pitch bends.
Steve
Log or pin post don’t make any difference as to the whole range, it only makes a difference to the way it tracks.
