I am currently working on a project where I'm trying to design and make my own throttle quadrant for flight simulator using Arduino for programming. However, I am very novice at programming and unsure what to do so I downloaded the Joystick library by Martini and tried to use already scripted code from a different throttle quadrant project by Fergobrick on Thingiverse. Flight Simulator - Throttle Quadrant/Pedestal - 737 inspired by Fergobirck - Thingiverse
Although the code works well for him I cannot replicate the same result. When I verify the code I get this error:
'Joystick_' does not name a type; did you mean 'Joystick'?
I even attempted making my own code based off his but just continue to get even more errors. My quadrent only has a Left and Right throttle with no gear switch or flap or spoiler axis and I am using an Arduino Mega 2560 with two 50k potentiometers.
#include <Joystick.h>
Joystick joystick(A1, A2);
//CALIBRATION
const int THROTTLE_LEFT_MIN = 159;
const int THROTTLE_LEFT_MAX = 497;
const int THROTTLE_RIGHT_MIN = 637;
const int THROTTLE_RIGHT_MAX = 309;
const int REVERSE_LEFT_MIN = 150;
const int REVERSE_LEFT_MAX = 70;
const int REVERSE_RIGHT_MIN = 639;
const int REVERSE_RIGHT_MAX = 719;
int axisLimits0[] = {0, 1023};
int axisLimits1[] = {0, 1023};
int axisLimits2[] = {0, 1023};
int axisLimits3[] = {0, 1023};
int axisLimits4[] = {0, 1023};
int axisLimits5[] = {0, 1023};
bool a0Used = false;
bool a1Used = false;
bool a2Used = true;
bool a3Used = true;
bool a4Used = false;
bool a5Used = false;
//PIN SETUP
const int THROTTLE_LEFT_PIN = A1;
const int THROTTLE_RIGHT_PIN = A2;
//ADC VARIABLES
int oldThrottleLeft = -1;
int oldThrottleRight = -1;
int oldThrottleLeftMapped = -1;
int oldThrottleRightMapped = -1;
int throttleLeftMapped = 0;
int throttleRightMapped = 0;
if(a0Used) pinMode(A0, INPUT);
if(a1Used) pinMode(THROTTLE_LEFT_PIN, INPUT);
if(a2Used) pinMode(THROTTLE_RIGHT_PIN, INPUT);
if(a3Used) pinMode(A3, INPUT);
if(a4Used) pinMode(A4, INPUT);
if(a5Used) pinMode(A5, INPUT);
Joystick.setXAxisRange(0, 1023);
Joystick.setYAxisRange(0, 1023);
Joystick.begin();
//Throttle
int throttleleft = analogRead(THROTTLE_LEFT_PIN);
if (throttleLeft != oldThrottleLeft) {
oldThrottleLeft = throttleLeft;
//Forward
if (throttleLeft <= REVERSE_LEFT_MIN) {
throttleLeft = constrain(throttleLeft, THROTTLE_LEFT_MIN, THROTTLE_LEFT_MAX);
throttleLeftMapped = map(throttleLeft, THROTTLE_LEFT_MAX, THROTTLE_LEFT_MIN, AXIS_LOW, AXIS_HIGH);
if (oldThrottleLeftMapped != throttleLeftMapped) {
Joystick.setXAxis(throttleLeftMapped);
Joystick.setRxAxis(0);
oldThrottleLeftMapped = throttleLeftMapped;
//Reverse
throttleLeft = constrain(throttleLeft, REVERSE_LEFT_MIN, REVERSE_LEFT_MAX);
throttleLeftMapped = map(throttleLeft, REVERSE_LEFT_MIN, REVERSE_LEFT_MAX, AXIS_LOW, AXIS_HIGH);
Joystick.setXAxis(0);
Joystick.setRxAxis(throttleLeftMapped);
int throttleRight = analogRead(THROTTLE_RIGHT_PIN);
if (throttleRight != oldThrottleRight) {
oldThrottleRight = throttleRight;
if (throttleLeft <= REVERSE_RIGHT_MIN) {
throttleRight = constrain(throttleRight, THROTTLE_RIGHT_MIN, THROTTLE_RIGHT_MAX);
throttleRightMapped = map(throttleRight, THROTTLE_RIGHT_MAX, THROTTLE_RIGHT_MIN, AXIS_LOW, AXIS_HIGH);
if (oldThrottleRightMapped != throttleRightMapped) {
Joystick.setYAxis(throttleRightMapped);
Joystick.setRyAxis(0);
oldThrottleRightMapped = throttleRightMapped;
throttleRight = constrain(throttleRight, REVERSE_RIGHT_MIN, REVERSE_RIGHT_MAX);
throttleRightMapped = map(throttleRight, REVERSE_RIGHT_MIN, REVERSE_RIGHT_MAX, AXIS_LOW, AXIS_HIGH);
Joystick.setYAxis(0);
Joystick.setRyAxis(throttleRightMapped);
Serial.println(oldSpoiler);
delay(50);
