Here's the code for making a time lapse shutter release for a Nikon DSLR. I have always wanted a high-definition time lapse camera, but this is the next best thing. Basically it just triggers the shutter release a number of times per second. I got the time values from here.
Change the #defines for your needs. Enjoy.
/* Time Lapse code by Morgan Jones. Feel free to use, modify, and redistribute to your will. */
/* Begin user defines */
The scale of your time lapse. 0 for frames/sec, 1 for frames/minute, 2 for frames/hour,
3 for frames/day, or 4 for frames/week.
#define SCALE 0
// The frame rate of your time lapse (see above).
#define RATE 2
// Your IR LED pin.
#define LED_PIN 12
// The built-in LED on your Arduino.
#define LED_ARDUINO 13
// Your camera model. 0 for D40, D40x, D60, D80 or D90. 1 for D80, D70, D70s, D50, or N65.
// For the D80, choose 0 (it's just newer).
#define MODEL 0
/* End user defines */
/* Begin preprocessor defines */
#if SCALE == 0
#define WAIT_MILLIS 1000
#elif SCALE == 1
#define WAIT_MILLIS 60000
#elif SCALE == 2
#define WAIT_MILLIS 3600000
#elif SCALE == 3
#define WAIT_MILLIS 86400000
#elif SCALE == 4
#define WAIT_MILLIS 604800000
#endif
/* End preprocessor defines */
/* Begin program variables */
#if MODEL == 0
static unsigned int code[] = { 2250, 27600, 650, 1375, 575, 3350, 650 };
#elif MODEL == 1
static unsigned int code[] = { 2000, 27800, 500, 1500, 500, 3500, 500 };
#endif
#define CODE_SIZE sizeof( code ) / sizeof( unsigned int )
// The LED's state
static boolean state;
// Start of the second
unsigned long then;
/* End program variables */
/* Begin program code */
// Start output on the LED pin and internal LED
pinMode( LED_PIN, OUTPUT );
pinMode( LED_ARDUINO, OUTPUT );
// Start this second
then = millis();
// Send the code 2 times
for( int a = 0; a < 2; a++ )
// Set the initial state to HIGH
state = HIGH;
// Send the entire code
for( int b = 0; b < CODE_SIZE; b++ )
// Turn the LED on or off
digitalWrite( LED_PIN, state );
// Wait a little bit
delayMicroseconds( code[b] );
// Invert the state. IR codes are a square wave, so we need an on-off cycle.
state = !state;
// Turn the LED off for 63 milliseconds
digitalWrite( LED_PIN, LOW );
delay( 63 );
// Turn on the Arduino LED while we wait
digitalWrite( LED_ARDUINO, HIGH );
// Do nothing until we can finish this second/minute/hour/day/week
delay( ( WAIT_MILLIS / RATE ) - ( millis() - then ) );
// Turn off the Arduino LED. We're done waiting.
digitalWrite( LED_ARDUINO, LOW );
/* End program code */
I haven't tested it out, but it should work provided you have an IR LED and a resistor (so you don't blow your LED; I just blew one tonight; don't do it) and your Arduino is in close proximity to your camera.
Update: Someone has already made this. Oh well.
