Do anyone have any clue how to use TimeZone library it in my project? I've tried but can't get it working...
How can I actually programme the DS3231 chip to keep the time with some help from the battery with the right timezone, I have +1 UTC? Yes I include the timezone library but can't figure out how to attach it to my project in a properly way
Code I got so far, work good for the other features that I want, just timezone and the external interrupts that doesn't work, which means I want it to go to sleep and when the alarm triggers, it will wake the Arduino up, same if I push a button and the go back to sleep. Any ideas?
Thank you!
#include <DS3232RTC.h>
#include <Streaming.h>
#include <time.h>
#include <Wire.h>
#include <LowPower.h>
#include <Timezone.h>
#define SQW_PIN 2
#define DS3231_I2C_ADDRESS 0x68
volatile boolean alarmIsrWasCalled = false;
int button_pin = 3;
int fan_power_pin = 9;
int wv_power_pin = 10;
int controller_pin = 13; //Starts to indicate that the system is running
void setup(void)
pinMode(button_pin, INPUT); //BUTTON PRESSED
digitalWrite(button_pin, HIGH); //
pinMode(fan_power_pin, OUTPUT); //Pin to power the PC fan
digitalWrite(fan_power_pin, LOW);
pinMode(wv_power_pin, OUTPUT); //Pin to power the water valve
digitalWrite(wv_power_pin, LOW);
pinMode(controller_pin, OUTPUT); //Starts to indicate that the system is running
digitalWrite(controller_pin, LOW);
Wire.begin();
setSyncProvider(RTC.get);
Serial << "RTC Sync";
if (timeStatus() != timeSet)
Serial << " FAIL!";
Serial << endl;
RTC.squareWave(SQWAVE_NONE);
pinMode(SQW_PIN, INPUT_PULLUP);
attachInterrupt(INT0, alarmIsr, FALLING);
//Set an alarm at every 20th second of every minute.
RTC.setAlarm(ALM1_MATCH_HOURS, 0, 34, 2, 1);
RTC.alarm(ALARM_1);
RTC.alarmInterrupt(ALARM_1, true);
//Set an alarm every minute.
RTC.setAlarm(ALM2_MATCH_HOURS, 0, 1, 0, 1);
RTC.alarm(ALARM_2);
RTC.alarmInterrupt(ALARM_2, true);
void alarmIsr()
alarmIsrWasCalled = true;
void loop(void)
displayTime();
time_t starttid = now(); //Variabel med den aktuella tiden då detta körs
bool alarmActive = false; //Variabel för att säga till att alarmet inte är aktiverat
bool RTCAlarmActive = false;
if (RTC.alarm(ALARM_1) || RTC.alarm(ALARM_2))
RTCAlarmActive = true;
while (now() < starttid + 5 * SECS_PER_MIN)
digitalWrite(wv_power_pin, HIGH);
digitalWrite(controller_pin, HIGH);
if (digitalRead(3) == LOW && RTCAlarmActive == false)
//IF BUTTON WAS PRESSED, THEN WATER FOR 3 MINUTES INSTEAD OF 5 AS WITH ALARM
// Ena stiftet p knappen till ground och andra stiftet till digital 2(interrupt Pin)
while (now() < starttid + 3 * SECS_PER_MIN)
//digitalWrite(rtc_power_pin, LOW); //if this line is commented it works as expected.
//LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val / 10 * 16) + (val % 10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val / 16 * 10) + (val % 16) );
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set DS3231 register pointer to 00h
Wire.endTransmission();
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
void displayTime()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
// retrieve data from DS3231
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
&year);
// send it to the serial monitor
Serial.print(hour, DEC);
// convert the byte variable to a decimal number when displayed
Serial.print(":");
if (minute < 10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second < 10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(" ");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day of week: ");
switch (dayOfWeek) {
case 1:
Serial.println("Sunday");
case 2:
Serial.println("Monday");
case 3:
Serial.println("Tuesday");
case 4:
Serial.println("Wednesday");
case 5:
Serial.println("Thursday");
case 6:
Serial.println("Friday");
case 7:
Serial.println("Saturday");
