Hi, a week ago I was playing around with a Node MCU 0.9 board and everything worked fine in my IDE. However, once I switched my board back to Arduino Uno I could not longer upload my sketches. This is the message I get:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\tyler\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error occurred while uploading the sketch
Does anyone know what might be the problem, I suspect it has something to do with the board switch over and not changing a setting back.
