//code write by Moz for YouTube changel LogMaker360 Arduino for beginners. Part 10: Timer Interrupts - YouTube
//10-05-2016
#include <TimerOne.h>
int motherLoopLedBlue = 7;
int timerInterruptLed = 8;
volatile boolean onOrOff = LOW; // set led on or off inside the ISR
volatile unsigned long functionCounter = 0; // count how many times the function is called
unsigned int motherLoopCounter = 0; // to pick up the value of the function loop
pinMode(timerInterruptLed, OUTPUT);
pinMode(motherLoopLedBlue, OUTPUT);
Timer1.initialize(2000000); // 2 million microseconds is 2 seconds
Timer1.attachInterrupt(function);
noInterrupts();
motherLoopCounter = functionCounter;
interrupts();
Serial.print("function is called = ");
Serial.println(motherLoopCounter);
if(motherLoopCounter == 12){
digitalWrite(motherLoopLedBlue, HIGH);
digitalWrite(motherLoopLedBlue, LOW);
//interrupt service routine function
void function(){
digitalWrite(timerInterruptLed, onOrOff);
onOrOff =! onOrOff;
functionCounter ++;
// this is the code for timerone library but it’s maximum timer between 2 led is is 8.5 seconds i need to maximize it to 5 minuite
