Hi there :0)
I got my TLC5940 Chip today and wanted to play arround with it.. yet unfortunately i seem ti be unable to use it...
I was not using the code i found at the playground as it was not what i was looking for (in terms of simplicity of use) but i found the follwiing library: Arduino/Libraries – Metalab Wiki
Can someone tell me how to wire everything up? I was doing the SIN etc pins just like the cpp file told me, but i have had no luck yet in running even a single led through it - guess that happened because i didnt set the cables for Power etc right... i was connecting GND to GND and Vcc to 5V - and i think the clue lies somewhere there..
OK, this seems to be solved.. i found Acelone's library with a good extended howto on how to connect the whole thing :0)
Alright so far i got one of them running, but when i try to chain them i run into a few problems.
* - Put the longer leg (anode) of the LEDs in the +5V and the shorter leg (cathode) in OUT(0-15).
* - +5V from Arduino -> TLC pin 21 and 19 (VCC and DCPRG)
* - GND from Arduino -> TLC pin 22 and 27 (GND and VPRG)
* - digital 3 -> TLC pin 18 (GSCLK)
* - digital 9 -> TLC pin 24 (XLAT)
* - digital 10 -> TLC pin 23 (BLANK)
* - digital 11 -> TLC pin 26 (SIN)
* - digital 13 -> TLC pin 25 (SCLK)
* - The 2K resistor between TLC pin 20 and GND will let ~20mA through each LED.
* If you are daisy-chaining more than one TLC, connect the SOUT of the first TLC to
* the SIN of the next. All the other pins should just be connected together:
* BLANK of TLC1 -> BLANK of TLC2 -> ...
* The one exception is that each TLC needs it's own resistor between pin 20 and GND.
* Alex Leone <acleone ~AT~ gmail.com>, 2008-11-26
I now have connected every pin coming from the arduino into the corresponding pin of the first TCL as well as into the corresponding pin in the second TCL - without, of course - SIN which is connected to SOUT on the first TCL. Now the thing is like that. I have a simple light which should run through all LEDs on the board, It works for the first TCL but it doesnt run through the second array. Even worse: The LEDs on the second TCL seem to blink in an erratic and random way.. alouth Out15 corresponds to TCL1 Out 11 or 12...
Any ideas on what i do wrong?
