Arduino to a SPI RFID reader
Hello, I have difficulty communicating a SPI RFID reader with Arduino.
In order to make the reader work, every time I need to send a command consisting of several bytes of data, e.g. CC 02 01 03. The returned message should look like BB 08 01 48 59 35 30 32 42 6F.
I looked through the SPI library in Arduino.cc. The major function is spi.transfer(). However, it sends 1 byte of data and reads back 1 byte of data every time. It may be ok to send the data by calling transfer() several times, e.g.
spi.transfer(CC);
spi.transfer(02);
spi.transfer(01);
spi.transfer(03);
But how can the arduino read back the returned message? For different command, the number of bytes of the returned message is also different.
Thanks a lot for your help.
No just keep on sending it as many bytes as you need, then keep on reading as many bytes as it sends.
These are two routines I use to read and write to a 23S17 port expander. You will see on the read, I write two bytes to it and read back one. On the write I just write three bytes.
byte expanderR(byte com,byte add) //// expander read
  byte value;
  digitalWrite(SS_PIN, LOW);
  Spi.transfer(com);  // address read
  Spi.transfer(add);   //  register address
  value = Spi.transfer(0x0);   //  dummy data for read
  digitalWrite(SS_PIN, HIGH);
  return value;
byte expanderW(byte com, byte add, byte dat) // expander write
  Spi.transfer(com);  // address write
  Spi.transfer(dat);   //  register data
