hello, ok so im a complete noob to all this stuff, this is the first project iv ever taken on like this and have next to no knowledge in this realm,so bare with me please...
basically i have an Arduino mini pr (3.3v) and i have programmed it to work with a xbox 360 chatpad using a modified version of cliffes code i found on github (will include code below), this code allows the Arduino to collect the serial form the chatpad bad and spits it out as the correct key press's on the Arduino ide 'serial monitor'...
i want to know if it will be a fairly easy thing to be able to change the code slightly to make the arduino act as an actually keyboard (ie send the keys to the computer as a standard keyboard rather than only being able to write to the serial port)
(this might be a problem)here is what i get in the serial port, as you can see i can type my name from the chatpad, but im not sure what all the other stuff is around it?, im guess (again with next to no knowledge) it is the message to keep the chatpad awake?....as it repeats those black ?/black diamonds, but it does type the letter you want...
this is what happens in the serial port (including my name i typed out 'iain')
��e���e���e���e���e�iain��e���e���e�
here is the library/coding i used
#include <Chatpad.h>
Chatpad pad;
void print_keys(Chatpad &pad, Chatpad::keycode_t code,
Chatpad::eventtype_t type) {
if (type == Chatpad::Down) {
char a = pad.toAscii(code);
if (a =='\t'){
Serial.println("Pressed right");
}else if(a=='\v'){
Serial.println("Pressed left");
} else if (a != 0){
Serial.print(a);
Serial.begin(57600);
pad.init(Serial1, print_keys);
pad.poll();
rest of code:
so yah, can anyone help me out here on getting this to work as a standard keyboard???
Since nowadays PCs don't have real COM ports, I assume that you're using an "USB as COM" stick for both programming of the Pro Mini and serial connection. Then you "only" have to convince your PC that a keyboard is connected to the USB port. I'm not sure if such an "USB as keyboard" adapter is already available, with a serial or other interface to a 3.3V Arduino.
Yes, I'm using serial to usb, to program and send serial to serial port....thanks for your reply
I thought it would be in the code (again next to no knowledge), like you would use eg 'keyboard.begin instead of serial.begin??
Ultimately Id like to add an adafruit blue fruit ezkey or ez link to make it wireless.....with this need further work or will it be as simple as attaching the arduino to the blue fruit tx/rx and changeing/adding some commands?
Thanks for your help, much appreciated and sorry if I'm a bit slow on the up take...really am new to all this...
