Arduino to be connected with ultrasonic sensor and electric horn and electromagnetic solenoid for automatic brake system
I am a student of class seventh, learning arduino kindly help to make the programme run I have been trying for my school project. Kindly provide the image and final coding. I have the following components: 1. Arduino R3 2. L298 motor driver module 3. 12 Volt Electromagnetic solenoid 4. HC- SR04 Ultrasonic sensor distance module 5. Electronic horn set 6. One 12-volt solar panel 7. One 12-volt battery 8. two 5 voltage battery 9. one relay.
I assume by "image" you mean a wiring diagram?
This wiring diagram and final coding that you asked for do not yet exist. They must be created. There are people who will create these things for you, but they will not do it for kindness. They will do it for money.
Since you are a student, I assume you will not have money to pay. I also think that if you did have money to pay, your teacher would not be pleased about that because the lesson is to learn how to do these things yourself.
This forum will help you to learn and complete your project for free. But the forum will not do everything for you. You must do most of the work.
HI @ayanmaity
welcome to the arduino-forum.
You are asking in a pollite way.
Still this forum does not work like a "can somebody post the 40 digit-cheatcode for a computergame.
What you are asking for is much much more work than typing 40 digits.
You are asking for the "global" solution. But without providing enough detail-information.
The users here in the forum will help you. If you look close into the forum-threads you will find threads with 300 or more posts. Each with more than just 40 characters. But they are all answers to specific questions.
Start asking specific question. These questions can be simple. Just ask specific.
If you read 20 minutes and follow the way described in the how to get the best out of this forum-tutorial you solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
have you connected any of the devices to the Arduino R3?
have you tested that they work? e.g. using library test programs if available
